Originally Posted by Obsidians
I don't think it makes sense to buy anything more than 7.2 if you're going to get the D2v. Buying for for the future is one thing, but you'd have 2 speakers and an amp completely unused. You're clearly not hurting for cash, but that's still pretty wasteful.
I'd go with:
Anthem:
(1) D2v
(3) M1
*(1) P5
That's 8 channels of amplification, so more than enough for the D2v's 7 channels of processing.
Paradigm:
(2) S8
(1) C5 + stand
(2) ADP3
*(2) S2 + stands
(2) Sub 2
The 2 S2s are for the rear channels. For the theatre design, keep in mind that you're spending about a hundred grand on electronics/drivers, so you want to budget some pretty significant money for the room itself to really get any kind of value out of that much high-end equipment. For instance, you're looking at well in excess of 20,000 watts of peak draw, so you're going to need some serious wiring to drive all of that load. You'd definitely want dedicated 240v lines for the subs and probably dedicated lines for the amps as well.
If/when you decide to go to 9.2 by adding heights, I'd recommend S1s, since they'd be much easier and less awkward-looking to mount high like that. If you wanted wides instead or in addition, I'd probably consider S2s on stands for that. Buying those additional speakers in advance wouldn't be especially useful since they'd just be sitting in a box somewhere until you changed out the D2v. I mean, I guess you could have them pre-installed waiting for some kind of D3v.....
I'd go with:
Anthem:
(1) D2v
(3) M1
*(1) P5
Paradigm:
(2) S8
(1) C5 + stand
(2) ADP3
*(2) S2 + stands
(2) Sub 2
I agree, that's a serious waste of such high quality speakers. The second pair of S2s would goto waste. Unless you wanted a 2.0 system in your toilet...
Considering I have a 11.2 paradigm studio system, I often move around speakers just to get hours on them. I recently began watching tv in full multi channel stereo mode so the speakers would be broken in and used.
