Originally Posted by falconxr6
Yes I have ran the room correction. In fact, I was using a MRX700 when I replaced the speakers to the Studios. The issue with the "squawkiness" from the midrange was there before and after ARC was performed. I then purchased a Yamaha RX-A3010 as I knew it had a customizable parametric eq so my aim was to tone down the midrange with this. It did help, but it had a side effect of the smoothness from the centre. I then returned the 590 and received the 690, re-ran YAPO and of course the "squawkiness" from the centre is still there. Not quite as bad as the 590, but still there none the less. Using a studio 100 as a centre works fine. No issues there. The old CC290 was fine. I had a listen (back to back of of the 590 against a signature C3 and the C3 did not exhibit the issue. The store did have the 690 in stock, but didnt want to take it out of the box for a comparision so I based my decision on a post someone had made about midrange localisation not being an issue with the 690 / C5. Guess that was wrong! I can't afford to go to the signature range now, and the retailer doesn't want to refund. I just have to figure out a way to attenuate the midrange driver a little, any ideas? 10w resistor? Value?
I certainly won't be reccommending Paradigm (or buying) again, that is for sure.
Originally Posted by Eldiablos
Have you run any room correction or rerun it after you installed it? Is the speaker mounted at the proper height? Is the speaker working properly as far as you can tell? It may also just boil down to your ears. I find that while we can measure and graph speaker's performance, each person's perception or hearing likes are different. Have you tried using one of your 100s as a center to see if maybe you are one of those people that needs a vertical center channel? I hope this helps as I know I myself would like to be happy and satisfied with the amount I spent on my studio setup.
If both 590 and 690 have this particular "squawkiness" with both Anthem and Yamaha, maybe it is not the speakers. Placement, cable and/or power lines? I do not own 690 but everyone that has 690 on this thread seem to be very pleased with theirs.
And I've never heard a bad sound out of it unless it was part of the source audio.
