AVS › AVS Forum › Audio › Speakers › Paradigm Owners Thread
Paradigm Owners Thread - Page 845
post #25321 of 28101
Originally Posted by 519audiofan View Post
I am thinking NAD M25 or an Anthem A5 (or a P5 if I can find one on CAM - I missed out recently on a mint condition P5 going for $3500.00) I picked up a Pioneer Elite N-50 network audio player last month and it has made a noticable improvement in the sound quality of my flacs so naturally the next upgrade should be an amp smile.gif
You'll probably get more bang for your buck by improving the front end than adding amps, and WAY more if you address room acoustics if you haven't already. YPAO is good, but a fair bit behind the curve of Audyssey XT32 & Anthem's ARC and all of them can really benefit from passive treatments first.
That being said, I had the M25 with my previous S4's and it was an outstanding match. I would still have it if I didn't sell it as part of a package with the M15. You should also look at wyred4sound's ICEpower offerings as well. Been using ICE with my Paradigms for eigth years now and they're tough to beat for a combination of power, performance and value. The PVA's were actually my favorite of the Anthem amps, for music anyways, if your room is on the smaller side they're another option.
post #25322 of 28101
Originally Posted by Brinfc View Post
Looking for some advice from other paradigm owners... I just came into a bonus at work and looking to grab myself a paradigm 5.0 setup (I'll probablly grab an HSU or Epik sub) My room is 19 x 14 and is a dedicated HT( 100% movies) room. Im runnin a Denon 3312 atm which i may or may not replace.
I have $3000 for a budget (for L/R/C and surrounds))and would like to know peoples suggestions, Monitor 9's , SE 3's , or start piecing a Studio set together?
I know the studios will break my budget but i could always add the surrounds later.
Any help would be appreciated.
I personally would recommend starting with the Studios and piecing the system together as time permits. That's what I did. I love my Studio 60's and am very glad that I went with the Studio line even though it means putting the whole thing together over time. I can't speak to the 60's vs 20's as I have not heard the 20's, but the 60's are fantastic for both music and movies and a noticeable step up from the monitors.
post #25323 of 28101
Having no center channel is really bugging me out. I talked to teh representative for paradigm in Barbados and he wants me to take teh entire speaker to him because he is not ordering the part for me without inspecting the speaker first. I didnt buy the speaker from him (simply because he overcharges big time) and that has him a bit peeved. Here we pay up front first and then receive the product afterwards so i was wondering why wouldnt he just order the part for me even if i still have to pay him up front. he was saying it could be the crossover that is the issue and that is why it seems as if the speaker is not clear. Could that be the reason? Can the crossover cause the distortion that i am hearing?
post #25324 of 28101
Yes absolutely. If the driver is fine and the crossover is defective it's likely a much cheaper fix too.
post #25325 of 28101
You should get the x-over checked out. I had a pair of ADP 1's that kept blowing drivers, couldn't keep them working for more than a month at a time. After replacing three tweeter/mid range assembilies and the dealer had the x-over checked out. That was the culprit for the blown drivers according to them, I just got rid of them after the third repair as that pair was just too much trouble to be bothered with them.
post #25326 of 28101
can i check the crossover on the C3 on my own? Also, can i replace it on my own?
post #25327 of 28101
If you're patient and don't mind used, there are great deals on Audiogon and the classified areas of forums like AVS. I recently got my front 3 Paradigm Signatures on Audiogon for 40% of (60% off) their original msrp. If these were sold to me as new, I would not have known they were used. And I am very anal about the condition of my toys. For 3k you can put together a 5.0 Signature "bookshelf" system.
Sent from my Nexus 7 using Tapatalk 2
post #25328 of 28101
Thanks everyone on the suggestion to use front wide channel for my signature 4's.
Can anyone suggest a 2 or 4 channel amp to use my Signature 4's as front wide or height speakers, since they will be unused now that I upgraded and got the Signature 6's.
My Parasound A51 is only 5.1 channels, but I have an Integra 80.3 with 9.2 channels and I don't want the S4's collecting dust I don't want to spend a fortune, since the amp will only be pushing wide, height or back channels, but I also want to suppliment the quality that best matces up to the equipment I have now.
post #25329 of 28101
Since you already have a Parasound Halo amp, Parasound A23?
post #25330 of 28101
Can anyone please advise me on this?
post #25331 of 28101
How do you connect Studio Sub12 balanced input or RCA L/R to a preamp? I'm currently using a receiver sub preout. But let's say I want to use a preamp that has both balanced and unbalanced outs for a 2.1 system. How do I do?
Secondly, do I need a crossover device? Anyone tried without one?
post #25332 of 28101
Thanks for the feedback. What pre/pro do you have now?
post #25333 of 28101
If it was my unit, I would pay the rep. to check it out to find out exactly what the problem is. Then you can make the decision whether to fix it yourself or pay him.
We have very good ones in my area and were able to find a problem on a new speaker I never would have found. Of course it was under warranty.
Good luck!
Edited by ayrton - 8/9/12 at 3:11pm
post #25334 of 28101
You're welcome.
I'm using the Denon AVP-A1HD and just had the XT32 upgrade done recently.
post #25335 of 28101
Hi all. I am getting ready to drive to Daytona from Orlando to hear a pair of Monitor 9 v7s. Before I drive the distance will a Yamaha A720 be OK with these speakers. Thanks in advance
post #25336 of 28101
Yes it should drive them just fine. Depending upon preferred listening levels, you may or may not want to add an amp (assuming the AV has pre-outs). But otherwise should be fine!
post #25337 of 28101
Originally Posted by KCWolfPck View Post
Hey all. I'm looking to purchase a pair of ADP-590's (for surround rears) and a pair of Studio 20's or 10's (for front heights). Looking for gently used or a good deal on new ones. I've been checking here, Audiogon, Craigslist, and eBay. Any other places I should be checking that I'm not thinking of?
An authorized Paradigm dealer?
post #25338 of 28101
What would be a good price to get new studio 10's from a dealer?
post #25339 of 28101
I'm not really near an authorized dealer and the ones that are sort of near (still over an hour away) don't sell used or traded in equipment.
Ok, original post stated used or new, so it wasn't clear. Are the dealers installers or showroom? I have found most showrooms do take consignment as an incentive to upgrade and have less hassle getting rid of your old items.
post #25340 of 28101
So.... I still didn't receive my Signature 6's, appartently the warehouse shut down last week. Told they will be here this week.
post #25341 of 28101
Been waiting a week and a half for my Center 3, dealer said the same thing about paradigm shutting down for a week to do inventory and said I should get it early this week.
Sent from my GT-N7000 using Tapatalk 2
post #25342 of 28101
It's good to know that the prices are going up. I was in the market to buy a pair of 60"s but now will buy the Sierra Towers..
post #25343 of 28101
I want to buy a used Paradigm speaker setup (piece by piece, unless I get lucky and get them all at once).
I'm on a budget, so used is my only option. Question is, which Monitor models, series, etc. go together? The model names don't make it easy to figure things out. I'd like to get:
- center channel
- 2 book shelf (max 15" x 21" HxW)
- 2 on wall surround
- sub (in reality doesn't need to be Paradigm)
The reason for the matched series and vintage is achieving the correct tambre, right?
Which models, series go with each other?
I like the Monitor series, so that's where I'd like to focus. Thanks!
post #25344 of 28101
- center channel
In the Monitor series,for the fronts check the Mini-Monitors (version 5or6)
Their dimensions are 13.5H x 7.5W. The center channel to match them
Is the CC-190 or CC-290. Stick with version 5 or 6. For the surrounds I
Would just go with the Atoms. subwoofer is totally up to you, many great
Values can be had that are not Paradigm. The version 5 and 6 are only a few
Years old and can be easily found used without as many hours on them
As the older versions.
Monitor series bookshelves smallest to largest, Atom,Mini-Monitor,Titan Monitor.
Center -- cc-190,cc-290,cc-390.
Addicted to BMW power;)
post #25345 of 28101
Originally Posted by liuwmmorales View Post
I hear a lot of people preferring a Mini Monitor compared to a CC-370, is it the same with a Studio 20 and a CC-470? Anyone can comment on whether they like a Studio 20 as a center better then say a CC-470, or even a CC-570?link
I am very happy with my 490cc with my Studio 10v5's for my bedroom setup.
post #25346 of 28101
Has anyone here compared the Signature S2 v3's with the B&W 805 diamonds? I recently sold my Studio 100 v5 system but I'm moving to an apartment and I think I'll be living their long-term. I've moved away from the idea of big speakers. I think smaller speakers can do a similar job and, in fact, better as the tweeters can be ear height when seated, something I struggled to do with the 100's.
Right now I'm looking, but my top two choices are the Sig S2 v3's and the 805's with the diamond tweeter.
post #25347 of 28101
I owned the S2 v3 for a year, very familiar with them. I recently auditioned the Dynaudio Focus 160 and Monitor Audio GX 100's. Both are comparable in both price and performance, it'll come down which ones you prefer. You should give a listen and see what you think.
post #25348 of 28101
I am thinking NAD M25 or an Anthem A5 (or a P5 if I can find one on CAM - I missed out recently on a mint condition P5 going for $3500.00) I picked up a Pioneer Elite N-50 network audio player last month and it has made a noticable improvement in the sound quality of my flacs so naturally the next upgrade should be an amp smile.gif I have been doing more 2 channel listening lately so the movie watching has really dropped off which is probably why I'll do an amp first. My RXV3900 does an excellent job with the S4's/C3 but I think there is opportunity for improvement. Having to buy stands for the S1s makes the Studio 10 more appealing since I can just plunk them down on my existing stands.
Your system must rock with those dual Seatons.
Like you I've been on a two channel kick lately and have only watched one movie with the dual SubM's, wasn't a movie that would give the subs a good workout either. I have no doubt that'll I'll enjoy with some of the new releases due out in the fall.
Have you given any thought to Parasound Halo? I thought the Halo amps sounded great with my S2's.
The Anthem and Nad are both solid choices, can't go wrong with either one. Keep us posted on what you decide.
post #25349 of 28101
But never demoed the B&W range or equivalent competing model? You say you owned the S2 v3. Did you not like them? What do you have now? Thanks.
post #25350 of 28101
The CC-590 & 690 are exceptional center channels with the 690 delivering a more detailed soundstage (imo). I have not heard the Studio 20, but have heard the 590 and own the 690, have heard the Studio 60s and 100s. The construction of the studio series is better than that of the monitors (mainly in the cabinet) so you will see a better performing speaker. I'd ask what front speakers you would be using to better suggest what would be the best center channel. But for what its worth, the 690 is an exceptional speaker.
  Back to Forum: Speakers
