Originally Posted by Gerry White
Thanks eljaycanuck,
I have no doubt that the gargantuan cc-690 is the way to go from a pure audio perspective, but I'm ultimately trying to balance a modern visual aesthetic with great audio. The TV will be on a Visualizm AV stand, so the only real place I can put the center channel is inside the 20" door. Here's a rough sketch of what I'm trying to achieve:
Paradigm + XBR + Visualizm.jpg 98k .jpg file
There'll be a white leather sectional sofa on the opposite end of the room.
With a more minimalist feel to the room, I don't see a 690 in my future...
Gerry
Thanks eljaycanuck,
Gerry
If you've only got 20-inches of horizontal space for the centre, you'd be stuck with the CC-490. Have you considered going to the C1 instead? It should be around the same price as a CC-590. I've got a similar balance (WAF) system on the go, and I've been very happy with my S1+C1 (3.1) setup. In my case, my centre channel cabinet space is a bit larger, so I could have fit either a 590 or a C1, but not a C3. When I spoke with Paradigm, they said that the C1 would have better audio quality than the 590 (which I suppose it should, being slightly more expensive), despite being a bit smaller. The C1 also looks much nicer in my opinion, especially if you're going for a modern minimalistic kind of look.
