LJG:
| Except the DVI distribution amp strips the HDCP so any DVI------->to RGBHV converter will work, the DVI-------> to RGBHV is not receiving an HDCP encrypted signal, read carefully what Kei wrote you are hearing it from the horses mouth. |
No, I am talking about the dedicated DVI->RGBHV converter which
also strips HDCP. No need to use the distribution amp to get that effect.
Also, I am well aware who I am speaking to, incidentally, as I own one of the distribution amps---bought it from Kei and her cohorts!---and I've seen one of the DACs in action.
Kei:
| It doesn't "strip" HDCP, it decrypts it. |
Well, I think we're having a simple disagreement about semantics here.
I say that if an HDCP device decrypts the HDCP handshake on input, and doesn't put it back on the output, then it's "stripping" HDCP.
(As a family man, it's either that or a wire stripper. No other kind will suffice. :))
