Hi...I'm back...:D
| I don't know how to be more clear on this. Do not use a HTPC as a source unless it is a VGA connector or you are trying to calibrate the HTPC itself. The video and PC standards are not compatible for levels. You could use the patterns from the HTPC to adjust gray scale only for other devices, but it would not be a preferred method. Your calculated gamma is likely to be in error for example |
Now
that's clear. I can tell that my questions have started to become somewhat grating on you, and that is why I have decided to ask in open forum...to spread the annoyance around to others...:p
| If you are looking for an inexpensive solution your HTPC is fine. I think the 6800 series is ISF certified but the 6600 is very good. I would get DVE PRO, use the included component adapter and adjust your high def inputs that are component with it. Make sure your DVI is set for video levels and adjust your DVI inputs with its DVI output. |
Great! Jeff recommended DVE Pro as well, so I guess $300 is a relatively inexpensive solution.
| If you pick up an Accupel (nice unit) you still can only calibrate the input. As a hobbyist I think you'd do pretty good with the HTPC and probably wouldn't spend more money if that was already available. |
I kinda figured that. The performance/extra cost ratio is pretty good...:)
| BTW, The older firehawk (gain 1.35) does have a color shift a few hundred degrees towards red if I remember correctly. The newer Firehawk (gain 1.25) I believe resolves this problem. |
I bought my Firehawk material in May of this year, so I assume that I have the newer version. This is also a good example of why I thought that the screen had a grayscale of its own and that offscreen measurements would probably be more accurate when the levels are sufficient to measure properly.
| Bob: if you are dealing with DVI, then hopefully your DVD player will align correctly with the correct digital levels. However, do not use your HTPC's analog outputs as a reference, as they won't usually conform to consumer analog voltage range unless you scope it and force it to, which I do not recommend. |
Yes, Chris, I am using DVI output from a 6600GT on both HTPCs. I used 3no's patterns and the information provided by you, cyberbri, and 3no to get TheaterTek's VMR9 output to track as perfectly as possible.
| Bob said he has properly maintained video levels in his HTPC. I agree that calibrating to individual sources is always preferable, however most sources that you can't put a DVD in won't have the ability to access any patterns to help with gamma. Assuming that the source in question is keeping with a relatively standard gamma curve, using a properly setup HTPC source, a DVD player, or pattern generator, etc, to observe the gamma of the display, etc, is as good as you are likely to get. |
That's basically what I figured. The HDNet patterns are broadcast for such a short time (and while I am working) that it makes it impossible to do any adjusting using them. My
hope was that by capturing both the HDNet and InHD patterns, that playback through a properly calibrated HTPC outputting 720p (the same as my Dish 811) would at least give me
something to use for adjusting PC HD playback, and would
hopefully look relatively good with the Dish 811 as well. Once I buy the DVE Pro set, I should have enough patterns to do a little better job, right?
| I agree if the levels are proper, but I have seen too many HTPC's that people believe are properly setup and they are not. |
Hopefully, mine is...:) I used the procedures outlined in this thread:
http://www.avsforum.com/avs-vb/showthread.php?t=523614
from my neck of the forum...:D
| And they should read my guide which explains it in detail . |
Yup, read your guide, too!
| For DVI and HDMI inputs, an upscaling DVD player with Avia/DVE/etc can be used in place of a signal generator. |
I've got a Panny S97 with the latest firmware on its way here (It's the one that Kris Deering just tested for his latest report :) ). Is that one ok?
