[quote=Dark Rain]I will post my settings for each input I'm using on my Sony 42A10 as I've gotten several PMs asking for it. We should probably keep bumping this thread to keep it active for a awhile.
These settings are for low/mid-level lighting for day and night viewing. All settings listed are CUSTOM with the exception of SD digital cable. These settings give a more "flat" look since my lighting conditons do not change very much. I don't like overly contrasted/saturated whites or colors. Fine detail is lost and it causes eye strain which makes viewing the TV less enjoyable.
Viewing distance from my 42A10 is around 8 feet.
*Please note the Color setting differences between the red push fix and out of the box color decoder settings. See the first post in this thread on directions to fix the red push.
SD analog cable using the A10's RF coax input:
*Calibrated by eye
*I don't use my Motorola 6412 cable box for analog channels because of the poor PQ
Iris - 1 or 2 depending on room lighting
Picture - 60
Brightness - 48
Color - 33 (CH-AXIS1 0002 red push fix - 40)
Hue - 0
Color Temp - Neutral
Sharpness - 30
Noise Reduction - Off
DRC Mode - High Density
DRC Palette -
Reality 65
Clarity 63
Black Corrector - Off
Advanced Iris - Low
Gamma - Low
Clear White - Off
Live Color - Off
I can't seem to get into the DRC palette. I tried all three of the vivid,standard and custom. How can i get in. I have the 50" A10.
