Originally Posted by
cinema mad
Are, So do you have A G70 CRT projector with A Moome HDMI internal card or HD fury ? for HDCP..
If the above is true, I am not sure if you are aware but 1080p is not optimum for A G70 it cant fully resolve that rez and will look soft compared to say 1080i / 1920x800p/ 810p/ 817p or 720p...
Also CRT's cant display A 24Hz frame rate as it's way to low for A CRT but can display 1080i/ 1080p @60Hz..
Cheers...
Hi
Thanks for all the help.
Yeah, I know about 24Hz.
I have read this about the G70 as well and It is not true, In my case anyway.
I have a 2.4 mt wide screen and sit back about 5 mt.
It is connected by a HDMI cable running into a Sony First Hdmi moome card.
I have the Sharpest, Cleanest picture you could ever want.
I have tried 1080i but I could see lines, I tried the 720p and it was soft.
I think that the guy who wrote this originally had an older G70, I say this because I Bought another G70 last month as a Back Up and the Guy I bought it from is a TV Tech Repairman.
He did try 1080p but it was soft and because he had read the same thing, that it cant fully resolve he never tried any further with it and stuck to 1080i.
He offered to come around and do the Astig on mine and lens flap.
When he walked in and saw the 1080P pic i had up from a blu ray his jaw dropped, He could not believe how Good the pic was and that was before we did any adjusments.
He ended up giving my G70 an Astig adjustment and a focus and the picture got even better.
The only thing we could think of as to why the 1080P worked so well with mine was that his G70 was one of the early makes with differant firmware and mine was one of the last to be made.
The tube condition on both sets was about the same 8/10.
Anyway back to my color problem.
The size of my picture is not the problem, when I said that James Bond looked like a Smurf I meant in Color not stature.
I tried to look at the pics in the link but they werent the best quality to tell if it was the same problem.
Peoples faces that have a Pink color turned Bluish and objects that are blue turned redish. I have tried the Color space and there is no differance.
Thanks again
