AVS › AVS Forum › Video Components › DVD Players (Standard Def) › Sony DVP-CX995V owner's thread
Sony DVP-CX995V owner's thread - Page 9
post #241 of 2194
New Information for RS-232 Modification
I received the following e-mail from JVB Digital, which has been creating quality modifications for various Laser and DVD players for years now, and they seem to be willing to investigate the possibility of modifying the Sony DVP-CX995V disc changer with an RS-232 connection. Maybe if enough people expressed interest in an RS-232 connection being added to their Sony DVP-CX995V, JVB Digital could make it happen. Here is their contact information:
digital@jvb.nl and www.jvbdigital.com
Currently. JVB Digital offers an SMPTE259M serial digital interface (SDI) for the Sony DVP-CX995V.
http://www.jvbdigital.com/jvb.asp?c...title&title=269
Quote: JVB Digital
Hi,
We are currently working on a modification for the player. RS-232 is normally
not something we support, but since the player lacks one we'll investigate
it (low priority though). The codefree modification should be available
within 2 to 4 weeks.
Thank you for your interest,
JVB Digital
Dearborn, MI 48124
USA
FOR ALL YOUR CODEFREE DVD & SDI MODIFICATIONS
Originally Posted by vonhosen View Post
Originally Posted by AML
If a player (say the denon 3910) already has DVI and HDMI what would the benefit of having SDI be exactly?
As far as I can see SDI does the same job as HDMI or DVI Only difference is no HDCP.
Yes, there is no HDCP is the main difference. Other than that I believe it depends on the implementation of HDMI or DVI in the source player.
SDI takes the digital data straight from the MPEG decoder (YCbCr 4:2:2, no analogue conversion , no copy protection) & typically passes that information as 480i/576i via a single 75ohm cable to a deinterlacer/scaler where these tasks are carried out (still in digital domain) before outputting directly to the display.
You are avoiding D/A & A/D conversions with the artifacts, loss of quality that MAY occur or be exaggerated by these conversions.
With DVI I believe players tend to be RGB 4:4:4 where as SDI is YCbCr 4:2:2. This means SDI is taking the info exactly as it is stored on the DVD not performing colour space conversions with the possible assosciated artifacts.
DVI shouldn't allow output of 480/576i either, only 480/576p. this means that deinterlacing is taking place in the source player as opposed to your external scaler/deinterlacer.
HDMI specs will allow output of 480/576i (but not all source players do it.) Arcam Dv29 does. If your particular player doesn't allow "i" output then again you can't use external scalers (possibly) superior deinterlacing, only it's scaling abilities.
That is my understanding of all this , of course I could be wrong.
Originally Posted by R_Willis View Post
Why don't you just purchase either the 777ES or the new upcoming model?
RS232 standard
The 777ES has the RS-232 port, but it doesn't have HDMI or up-scaling and the 777ES has bugs in the Disc Explorer firmware that the DVP-CX995V has fixed. Also, it doesn't appear that Sony will update the 777ES with HDMI, up-scaling or fix it's bugs.
All the DVP-CX995V needs is the addition of the RS-232 port to be an improved equal of the 777ES with the exception of some picture fine tuning adjustments.
Adding the RS-232 will enable the use of an external media management controller like the Escient Fireball or Elan Via! dvdj which will create the ability to daisy-chain three or four changers (1200-1600 discs) and provide faster, more detailed, accurate and reliable automatic title management capability through the internet.
Originally Posted by c_hernandez32 View Post
According to a Sony rep, the ES line will be primarily for Blu-Ray players. As of now, there are not mentions of an upconvert DVD player.
I have heard the same thing.
Originally Posted by kevinp8192 View Post
la916 --
Would just adding an rs-232 port really help? I mean, just because a port is added, does that mean it would support all the two-way rs-232 commands that 777ES does? Or would it maybe have it's own set of commands?
My Sony TA-E9000ES was extremely similar to the Sony str-da777ES receiver, and both included included an rs-232c port. HOWEVER although they had almost the exact same feature set, and even used the same IR commands, the TA-E's rs-232c port could not accept the 777ES' rs-232 commands.
So for an rs-232c upgrade for the 995V to be viable, it would have to be fully compatible with the CX777ES' protocol.
Originally Posted by la916 View Post
I believe JVB would use the CX777ES as a reference for their upgrade. JVB has worked with the CX777ES and also provides a few upgrades for it.
Originally Posted by Johnla View Post
There is no guarantee that the 995 would be able to work with RS232, it takes a lot more than just adding a RS232 connector to the device. And if the circuitry within the 995 don't have support for it, then it probably can't be done unless you swap parts/circuit boards from a 777ES into it. Don't forget, they only told you they may look into the possibility of maybe doing of it. Plus if you look at the cost of their other mods, if it can be done, then it likely is not going to be cheap.
Yes, you are correct at this point, there are no guarantees until they research and possibly build and test this modification. I am sure it is possible to add this funtionality to the DVP-CX995V, but I am not sure if it will be a simple modification or will entail a complete re-engineering that would cost more than anyone would be willing to pay. Well, at least JVB is willing to consider the possibility of adding this capability. If an RS-232C port for the DVP-CX995V becomes reality, it will open the door for several options that will improve the overall disc management capabilities.
According to the thread below on the Agoraquest.com site, this guy modded his 4 985s to 777, adding a rs-232c port, with above average soldering skills and less than $10 in parts.
http://www.agoraquest.com/viewtopic....18909&forum=50 (it's about halfway down the page, username "surgeon")
After upgrading the 985's firmware with the 777's, it worked exactly as a 777, even being recognized by the Escient as a 777. It may very well be the same for the 995 as well.
Originally Posted by surgeon View Post
On 2005-02-14 22:00, Surgeon wrote:
On 2005-02-13 09:31, indecision wrote:
Surgeon,
Where can I find out more about modding a 985 to accept RS-232 commands? I searched here and at AVS forum but did not come up with anything.
Did you actually add the port to your unit?
Davis
If/when I find the time I may publish more info (ie: a step-by-step guide) on how to do this. Basically it involves 4 basic procedures, which can best be determined by obtaining copies of the technical service manuals for both the 985 and the 777 and doing a *lot* of comparisions between the two units. The 985 conversion steps involved are:
1) Removal of the "pull-up" resistors for the RS-232 inputs from the left-front panel board and connecting instead to the feed lines.
2) Building a small RS-232 to 3-volt interface (exactly as found on the 777's serial board) consisting of a Maxim MAX323 chip & caps.
3) Upgrading the 985's firmware to the 777's (modified version as in step #4 below).
4) "Moding" the firmware so it ignores the model desigination resistors and sees the unit as a 777.
The entire conversion requires less than $10.00 in parts but does require above-average soldering skills in acomplishing step #1. If you haven't worked with smc boards in the past, this isn't the place to start...
Once converted, even a Escient would connect to and operate the 985 exactly like it was a 777.
As stated previously, I've "upgraded" all 4 of my 985 units in this fashion...
-Surgeon-
Thanks for that infornmation kevinp8192. It provides hope that an RS-232C port modification may be accomplished. Also quoted below, thanks to robtwilk for providing some additional insight into the usefulness of a RS-232C port.
Originally Posted by robtwilk View Post
Here's are tidbits of info I have collected over the years:
I own the old Sony 200 DVD jukebox and the original 400 jukebox.
RS232 - I use DVD Profiler to track my movie collection (which works perfectly). I then use a program called Movies! to control my 200 disc jukebox. It imports data from DVDProfiler and then allows me to pick movies and play them from my PC (very cool interface with a real home theater look). It has to use a RS232 port for direct control (which my 200 has) or you can buy the IR adapter (which I have not tried). My 400 jukebox does not have the RS232 - which really bugs me. I wanted to buy the ES, but it was too much at the time. Now I have to consider the replacement for the 777 (RS232 and HDMI - $$$) or the new 995 (no RS232, but HDMI $$).
Autoplay - The autoplay feature drives me nuts!! Stupid, stupid, stupid!
Remote Control - I have used several remotes from $20 to $1,000. The ProntoPro did a decent job with the Sony, but the programming time was crazy. I had a super custom setup with DVD pictures and everything. The new Harmony 880 rocks for a $250 remote. It is an unpublished feature, but it controls the Sony 985 like magic. You can import a .CVF file from DVD Profiler or manually enter the titles into the proramming website (all 400) and then update the remote. Now, when you are in the "Play DVD" activity and press the "Media" key, it will show you alpha ranges [A-F, G-K, etc.], when you pick a range it will show you all movie titles in that range, then you push the button next to the title and it sends the correct sequence to the player. Works EVERY time!
That's all I have time for now...
Originally Posted by Kingdaddy View Post
The Direct Disc command in the RS232 protocol is the main difference with the 777ES. This command alone will alleviate most all the problems expressed in this thread. With the RS232 connected to a computer and a third party navigation system like DVD Lobby there is no issue with autostart/autoplay and no navigation or cover art issues. The only drawback is a slow layer change that is easily forgotten once you get used to it.
Don't expect Sony to do anything about the outstanding issues, they never have in the past, and they never listen to the complaints of the customers, they truly don't care. They will put out another generation of players with the same problems over and over again. The only way out is to use the ES model with a third party solution that will do what Sony obviously cant. BTW you do not need a dedicated computer to connect up to the RS232 and control the player, I use my computer for all my music and DVD selection and can still surf the web with no problems. Get a Viewsonic Airpanel, do the RDP hack and you will have true networking capabilities. My Airpanel is always set to Main Lobby and available to select Music or Movies and does not interfere with the server at all.
In summery, the RS232 is all the difference in the world, I would never buy a changer without some kind of outboard control port
Kingdaddy,
Thanks for the input. I will continue to pursue the third party RS-232C port development with JVB. Hopefully, others that like the options an RS-232C port can offer, will also e-mail JVB and let them know their interest.
post #242 of 2194
FYI:
I was at Circuit City today and they had this player for $349 and then there was a $50 mail-in rebate so the final price was $299.
Too bad I'm not ready to buy this yet.
post #243 of 2194
Kingdaddy,
It likely would be better to just buy a 777ES, because it will probably be cheaper in the long run if you are planning to go with multiple changers. You can easily find the 777ES for about $550, vs the $300+ for the 995 and whatever the mod price would be, and my guess is that it would be possibly be as much as the SDI mod is. Plus the 777ES has a 5 year warranty. And if you are going with the plan of setting up multiple changers and really want the HDMI conversion, considering what the mod may cost. You could probably buy a outboard scaler like the new DVDO iScan VP30 and 2-3 of the 777ES's, and still end up spending less than modding 2 or 3 995's to try and do the same thing.
post #244 of 2194
Originally Posted by dae3dae3 View Post
FYI:
That's the DVP-CX985V, not the 995.
post #245 of 2194
The 985 was open box 10 ft to the left.
They had the price tag under the 995. Maybe they messed up but the 995 was clearly the player that was marked as I described.
post #246 of 2194
Well my first 995 will be going back to Sony for service. Besides the popping noise (when a disk is cued up) and the memory loss (400 question marks instead of titles) the unit now can't remember where it left off on a given disk. It now starts at the beginning of each disk. The memory function used to work...but no more...
I did speak to Sony's Tech service. That was a complete waste of time. I knew more about the unit then the Tech did..that ridiculous, when is Sony going to give these people proper training?
I did mention the auto-play function and the inability to shut it off. The tech said it should be turned off in the menu options..I tried to explain I did that, but then I just gave up...
One thing I don't understand. He wants me to send the unit back to Texas. Gee, a week in UPS's hands won't that help matters a whole lot? Yet there is Sony's "Eastern Service Facility" located in New Jersey...Why can't they handle the repair?
post #247 of 2194
I don't know where you bought your 995, but I would head back to the store and demand a new one. I spoke to tech support too once about the auto play mode. He said my unit was faulty and I should send it to Texas too. I am in California. What a crock. No walk in repair service any more I guess.
post #248 of 2194
It's past the 30 day return policy, so I'm stuck...Sony service isn't what it used to be.
post #249 of 2194
Greetings,
NPY, sorry to hear about this. Keep us in the loop regarding the progress and outcome.
post #250 of 2194
Question...
Just talked to Sony. For repair or exchange it takes them 10 working days. Why the repair time & exchange time is the same I just don't understand...
Anyway, it will take a week to get there and a week to come back...so I'm looking at a month. That in itself is horrible service...
My question is: "Should I have mine repaired or get a refurbished unit"
Pros ? Cons?
Let me know what you all think....
post #251 of 2194
In trying to get my BENQ8700+ to recognize the HDMI signal coming from the Sony 995 (unsuccessfully to date), I've noticed that the signal being received by the projector's DVI input (I'm using a HDMI to DVI cable) reads 520P no matter what setting I put the Sony into (auto or 720P settings)
When I run my HD sat. receiver through the projector it reads either 720P or 480P depending on the setting on the HD sat. box, so it does appear to sense and read out the signal type coming in.
Anyone know why the Sony appears to be sending out a signal read as 520P? Is this my problem?
post #252 of 2194
That sounds like it is set to output PAL. Check the back of the player, some of them have a switch to select either PAL or NTSC.
post #253 of 2194
I tried out the 995 past weekend ... tried to get it to send a 1080i signal to my Infocus 4805 projector (its capable of it ... but does 480p natively) ... but the player refused to send anything but 480p to the projector. Sony CS said that since the infocus only does 480p natively ... thats what is going to be sent ... which does not make sense because my cable box (SA 8300HD) outputs 1080i fine using the same HDMI->DVI cable. So something is wrong with the sony unit. It went back to the store during the weekend.
Max
post #254 of 2194
A lot has been said on this thread about the DVP-CX995V 's AutoPlay bug, and let me say up front that I may have missed this workaround in a previous post..... but here goes.
I am going to assume that most users of this thread have macro remotes.
All I do is when I power up my system..... tack on an extra 15-20 second delay on the end of my startup macro and have the macro hit "Folder".
post #255 of 2194
Max
Greetings,
You need to set the HDMI output from Auto to 1920x1080i in the display settings menu. If you leave it set to Auto then the unit will only output the native resolution of the dispaly it is connected to.
In reality sending a 108oi or 720p signal from the Sony to the Infocus won't yield a picture that is any better than 480p anyway. The projector will just recale it back to 480p and you now have the signal being scaled twice ( once by the Sonly and then again by the projector ) which is not optimum.
I think your missing the real benefit to having a player that has a digitial video output going to a display with a corresponding input. tHe signal remains in the digital domain without needing to be converted from digital to analog to digital.
post #256 of 2194
NoPlasmaYet:
It makes me a bit nervous that Sony has a bunch of units to exchange. I usually prefer to get my own product fixed, but since these are so new, even the re-manufactured ones have very little wear on them. But, who knows what kind of abuse it took.
post #257 of 2194
Since my first CX995 is on it's way back to Texas, I spent some time using my second one. Much to my surprise the "Multi Disk Memory Function" doesn't work. If I stop a disk, turn the unit off and then later turn it on the disk resumes play in the spot I left off. Yet, if I stop a disk, go to another disk and then return to the first disk, the disk starts from the beginning (not where I left off). I found the same thing happens regardless of what disks I go to. The only time the unit remembers it position is if I stay on the that disk.
Can anyone else confirm the memory function?
And yes, I have it turned on in the setup menu.
post #258 of 2194
Originally Posted by mdeligny View Post
I've had this happen to me a few times already. Let the system "load" whatever it could find...then one day it comes up with a "?" near a disc that already had information manually entered in by me. This had to be done over and now the disc loads ok. This happens rarely, but it does happen and is a pain in the neck. This is why I do this...I keep a list of my movies ONLINE so I can browse that way which includes DVD plots, actors, stuff like that. I've decided not to use the built in navigation because it's a little behind the times if you know what I mean. What Sony or any other company should do is throw an Ethernet connection on this thing, have it point to imdb.com or some where else there's a good database and then have a real navigation screen. That though, will be years and years before a company does that...since they have a hard time just making simple navigation now. Here's my DVD list I use now...instead of the built in Sony's.
www.photopiks.com/dvd
What program did you use to set up your movie database online. Great idea
post #259 of 2194
Why not just print up your own DVD database using an Excel worksheet?
post #260 of 2194
I use DVD Profiler.
post #261 of 2194
DVD Profiler doesn't really help when you're in the living room wanting to find a movie in your jukebox unless you have some fancy contraption where you have a PocketPC and WiFi to use with your HT equipment.
post #262 of 2194
FYI:
Tell me more about this $50 rebate. I bought mine at Circuit City today and there was no rebate.
post #263 of 2194
I picked up this unit today.
I am trying to decide between this, the Oppo, and maybe the Samsung.
First, this is my second Sony mega changer, my first (which I still own) was the 300+1 flip changer that I loved (but hated the Explorer software back then).
It blows my mind that Sony has done little to improve the software making an important part of a changer, useless.
First, almost 99% of DVDs have a title associated with them on the DVDRom layer. There should not be a need to enter a single title in the explorer. Why Sony can't have the unit read the disc label is beyond me. It should be a fairly simple process. No, they would rather have users enter 400 entries on their keyboard.
This is my second upconvert player. I already own a Samsung HD931, the grandady of upconvert players. I like that player but wanted a HDMI interface for my new DLP.
I'm not sure I'm seeing much of an improvement over the Sammy. I put on the landing scene from Starship Troopers Superbit and it was very grainy. I have to play it on the Sammy to see if it is the same. The pic looks slightly soft to me. Monster's Inc. looked more digital than film like, which I was hoping for.
Oh well, I have 30 days so I'll give it my full workout.
post #264 of 2194
Nothing more for me to tell. The tag said there was supposed to be a rebate. I didn't have the money to buy one yet so I didn't look into it any further. It may have ended. Your guess is as good as mine.
post #265 of 2194
I log all my DVD's on DVD Profiler. Then print out a simple 2 or 3 page report that is in the same order as my Sony.
post #266 of 2194
Greetings,
I saw the 985 at Circuit city for $350 with the rebate, not the 995. They look almost identical.
post #267 of 2194
Well, no rebate at my Circuit City. Must be a regional thing. I thought you might have had a special rebate from Sony.
post #268 of 2194
Ok here is the concept I have, and hopefully someone with much more knowledge than I could help out.
I have a 985V with almost 400 discs in it, I have a Tablet PC and also DVD Profiler, does anyone know if there is a feasable way to have the tablet control the 985 and have all coresponding features of the DVD Profiler, I have a Toshiba Tablet with IR port on front, or I could buy a IR transmiter to send signal to machine. I would like to know possible software or any other posibilities, also on that same note, could my tablet be set up as a Home theater PC?? Which would require control of Lutron lights, Panny AE700, Yamaha 5860, Sony 985V, and even HD-SAT reciever. That would be incredible functionality from a currently owned unit (ie. Tablet Pc)
I really don't know much about Media Center Windows system, maybe that is all I need and I really don't know it. Any and All help would be appreciated, and no idea is too off the wall.
post #269 of 2194
A quick update to my tests...
I tried a Dual Layer test backup of the Aviator (which wouldn't play correctly in my Samsung) and it worked great.
The picture was jaw dropping.
So far, I am very happy.
post #270 of 2194
I could do the same thing with Excel...
I don't know about tablet PCs but there are a bunch of infrared remote control software apps for PDAs that turns it into a universal remote with touchscreen control. In fact if you have a PDA you can even store your own database on the PDA itself or if you prefer access your database from online using WiFi.
I myself am thinking of getting a Palm PDA to use as a universal RC in addition to having WiFi internet access.
Anyway I just purchased a 25pk spindle of Ritek DVD-R DLs which I'll be loading into the jukebox. Does anyone know if DL Riteks play in the 995?
  Back to Forum: DVD Players (Standard Def)
