AVS › AVS Forum › Display Devices › CRT Projectors › Shadow detail/gamma enhancement for the analog sources
Shadow detail/gamma enhancement for the analog sources - Page 2
post #31 of 492
Ignorant question: Why does device do a better job of lower ire gamma adjustment than a HTPC video card? I ask because this is great if it works and I want to build one!
TSE, maybe you could offer a kit. That way you could make some well earned money for all your work.
post #32 of 492
Clarence,
Your post makes perfect sense to me!!!
YEAH RIGHT!!!
What the heck is all that stuff?
post #33 of 492
Originally Posted by ChrisWiggles
barco 808. last time i checked it was a crt. but maybe i should check again. har...
Chris, you're just suffering from radiation poisoning. :p
post #34 of 492
I'm not sure it DOES do a better job than an HTPC. But for those of us who don't HAVE an HTPC, this is an attractive option!
post #35 of 492
Actually techman,
judging by Chris' informed posts in the Digital Hi-End Projectors Forum, he's far from a digital virgin. I'll have to footnote the amnesiac effects in my thesis. :D :D
John
post #36 of 492
Hope I don't sound like a r@sshole, but might I suggest keeping the name calling confined to the other 2 gamma threads that spiraled off topic.
It looks like TSE did a great job with these circuits and I'd hate to see a third thread ruined.
post #37 of 492
I'll second that... I have the wherewithall to build these beauties and want to see this tse design to conclusion (or at least gerber files!)
post #38 of 492
Phil,
This circuit is a gamma adjustment circuit, it adjusts a part of the gamma curve. HTPCs adjust the whole gamma curve, although I'm sure algorythms like Rec.709 could be easily implimented in video card drivers to tweak the gamma curve too.
Clarence,
Just stirring, but your point is taken.
Cheers,
John
post #39 of 492
Originally Posted by misohorny
Clarence,
Thanks John. I like slinging OT jabs too, but I didn't want tse to get frustrated by the heckling.
post #40 of 492
Originally Posted by WTS
Hi Darin,
Actually I've included the tse circuit in my transcoder design which will be on the new Moome card, but only for the transcoder section not the HDMI section.
Would you care to share more info on the new Moome card?
Thanks!!
post #41 of 492
It won't do a better job than a HTPC video card. That's going to be alot more flexible than this circuit. What this will do is give people that only have DVD and HDTV receiver analog sources a way to enhance the shadow detail and set the black level at true black.
post #42 of 492
Clarence,
Nice job on the parts list. Damn, there's that many parts in this thing?
post #43 of 492
Yeah, lots of parts... expecially when you list them separately for the RG&B circuits.
Can you verify that C17 is 100nF?
Clamp C16 100pF
Clamp C17 100nF
Clamp C18 100pF
Also, for what it's worth, I tried to get a WAG on the component costs
(not including the resistors and capacitors... are there any listed that would cost more than about a dime?)
Clamp U9A 74HC4538 $1.17 http://www.newark.com/NewarkWebComme...KU=38C1094&N=0
Clamp U9B 74HC4538 $1.17 http://www.newark.com/NewarkWebComme...KU=38C1094&N=0
Misc U3B/C/D 74HC86 $1.10 http://www.newark.com/NewarkWebComme...KU=38C1097&N=0
Clamp R14 2.2K $0.49 http://www.newark.com/NewarkWebComme...&Ntk=gensearch
Sync U3A 74HC86 $1.10 http://www.newark.com/NewarkWebComme...&Ntk=gensearch
Misc D3 1N4002 $0.03 http://www.newark.com/NewarkWebComme...&Ntk=gensearch
Clamp R21 50K variable $2.55 http://www.newark.com/NewarkWebComme...&Ntk=gensearch
VID_R U2 HFA1100 $3.45 http://www.newark.com/NewarkWebComme...&Ntk=gensearch
VID_G U2 HFA1100 $3.45 http://www.newark.com/NewarkWebComme...&Ntk=gensearch
VID_B U2 HFA1100 $3.45 http://www.newark.com/NewarkWebComme...&Ntk=gensearch
Sync U6 LM311 $2.60 http://www.newark.com/NewarkWebComme...&Ntk=gensearch
Misc F1 RXE040 $0.24 http://www.newark.com/NewarkWebComme...&Ntk=gensearch
VID_R D1 SD101A $0.05 http://www.newark.com/NewarkWebComme...&Ntk=gensearch
VID_G D1 SD101A $0.05 http://www.newark.com/NewarkWebComme...&Ntk=gensearch
VID_G D2 SD101A $0.05 http://www.newark.com/NewarkWebComme...&Ntk=gensearch
VID_B D1 SD101A $0.05 http://www.newark.com/NewarkWebComme...&Ntk=gensearch
VID_B D2 SD101A $0.05 http://www.newark.com/NewarkWebComme...&Ntk=gensearch
Sync D7 SD101A $0.05 http://www.newark.com/NewarkWebComme...&Ntk=gensearch
Sync D8 SD101A $0.05 http://www.newark.com/NewarkWebComme...&Ntk=gensearch
SH_R U7A/B TL082 $1.50 http://www.newark.com/NewarkWebComme...&Ntk=gensearch
SH_G U7A/B TL082 $1.50 http://www.newark.com/NewarkWebComme...&Ntk=gensearch
SH_B U7A/B TL082 $1.50 http://www.newark.com/NewarkWebComme...&Ntk=gensearch
post #44 of 492
Clarence,
C17 is 100nF, C16 and 18 are 100pF.
Your prices look about right. I'll post a parts list soon.
post #45 of 492
The gerber files and the pcb file.
*.gb0 is solder side
*.gb1 is component side
*.gb15 is top silkscreen/board outline
*.nc is drill drawing
www.apcircuits.com has a free gerber viewer as do most pcb web sites. There was mention of another earlier in the thread. Remember, you import gerber files into the program not open them like most programs do.
Comments, suggestions are welcome. I did this layout manually and I always make a mistake or two. Look it over, if you like, and tell me what you think. I'm going to wait a couple of days before I send it out for boards.
If you want to look at the PCB file, the demo for the program that I used is located at www.waldherr.com It's a neat little program.
AVSGamDCR.zip 206.5400390625k . file
post #46 of 492
I've taken the liberty of uploading these files onto the freedfm service at 4pcb... I should have a response whether their automated checker spots any troubles shortly...
--Edit: There it is:
--Edit2: The autochecker found and fixed silkscreen line width problems (they require 7 mil line widths) which may result in less readability.
TSE-001 Gamma Correction Circuit.pdf 28.1435546875k . file
post #47 of 492
Neat! $7.00 each for a hundred if you can wait four weeks. That's not bad.
Two boards from AP Circuits will cost about $90 and they don't have solder mask or silkscreen. But. I only need one so I think it's still the best deal.
post #48 of 492
Let me check with PCB Express... the $51/3 deal may apply with this board size, 2 layers.
post #49 of 492
The 4PCB boards arrived for my work project... They look good (no solder mask, which makes the silkscreen hard to read...)
At lunchtime I'll look into getting pcbexpress to quote what I've taken to calling the TSE-001 Gamma Circuit.
post #50 of 492
The quote from AP Circuits for two boards:
AP Circuits® Basic Prototype Estimate
2 circuit boards of 3.4" x 8.2" on FR4 .062"
(8.6 cm x 20.8 cm)
No soldermasks, no legends, shear cut
Lot Charge $46.00
FR4 .062" Materials Fee $36.24
Extra Drills Fee $0.00
Drilled Slots Fee $0.00
High Density Drilling Fee $0.00
Bottom Legend Fee $0.00
Milled Slots Fee $0.00
Estimate Total $82.24 US*
*Shipping and handling charges not included.
*Applicable taxes not included.
They ship Fed Ex next day which adds $20.00
post #51 of 492
The ExpressPCB "ProtoPro" service may prove a better price/performance point... four production-style (soldermask and silkscreen included) boards for $179USD.
http://www.expresspcb.com/ExpressPCB...csProtoPro.htm
ProtoPro boards have top and bottom copper layers with all holes plated through. They also include top and bottom soldermask layers giving the boards a green color. On the top surface is a white silkscreen layer showing the component outlines. The solder mask layers give the boards a very professional appearance.
ProtoPro designs must fit in a 21 sq-in rectangle and no dimension can exceed 12". With each order, we send you 4 identical boards.
Sounds like cleaner, prettier boards, with a two day turnaround.
post #52 of 492
OK, ExpressPCB (using their focmula and volume discount structure from their web site) would be $8.80USD per board plus shipping for 100 pieces with a 10 day turnaround ("Production" boards.)
Quantities from 50-99 would be $9.21 each, and from 2-49 would be $14.76.. this is far better than 4PCBs' $23-$42 each in 5-10 quantities.
This board is too big for the as-advertised 3 for $51.00 price.
post #53 of 492
If anyone just wants a quick peek at some of the Gerber files:
http://img361.imageshack.us/img361/1369/tsepcb3hu.gif
http://img361.imageshack.us/img361/5452/tsegreen0io.gif
post #54 of 492
ExpressPCB requires the board layout be done in their software, which has no import/export functionality. Bizarre, and business limiting. Oh well.
post #55 of 492
Back to 4PCB... They called me for a follow-up to determine if an order would be forthcoming... I mentioned that a short run of prototypes would be first with a more quantities later.
Sales0chick mentioned two specials they are running (I get the impression that there is always something special going on here...)
1) 3 for 33 special... $99USD for three two-layer boards with soldermask and silkscreening.
2) 2 for 4 special... Four week price on two week turnaround.
The 3 for 33 each pricing is quite a bit better price and appearance than any of the proto costs I've seen thusfar.
post #56 of 492
How can I do something like this with my HTPC? I use FFDShow for gamma correcton right now, but it adjusts the whole gamma curve and not just part of it, correct? When I adjust it to get acceptable shadow detail I no longer get absolute black during a fade to black.
What can I get to help my HTPC do what this thing that TSE has made does? Certain video card? Modded video card? What?
I woud like to have absolute black again if I could, but right now the cost is just too much (black crush).
post #57 of 492
That does sound like a good deal. I'll check it out.
post #58 of 492
1) Avoid using the FFDshow gamma adjustments, I believe it only operates in 8-bit. This will introduce banding problems.
2) depending on your video card, you should use that. Nvidia has good simple gamma adjustment, as well as I believe many have more advanced adjustments allowing you to make spaghetti out of your gamma curve if you so desire! It also makes these adjustments at I believe 10 bits at least, so this helps avoid banding.
When you are adjusting gamma, be sure to do it sparingly, and view bright scenes as well. Many times people will adjust gamma while looking at dark scenes, and keep seeing more and more shadow detail and raise their gamma curve far too much. What you are doing is crushing the contrast in the bright portions of the image and your depth will suffer and things will look postery and flat in bright scenes. The better way to do it is to move back and forth between a dark scene and a bright scene and find a good interplay between shadow detail and depth/contrast in bright scenes. Also, if you figure your CRT has a gamma of close to 2.5, you can just shoot for a target gamma maybe .2 or .3 less than that. If you have a non-LC machine, you will want to have a slightly lower final gamma number than an LC machine, because of the lower ANSI contrast (this means raising the gamma curve in the electronics more). An LC machine will maintain shadow details better, so there is less of a need to try to elicit low-end detail, and so you can be more conservative with your gamma adjustments.
post #59 of 492
G'day Folks,
following TSE's initial posting on using electronics to replace the typical video card gamma correction function, it got me thinking that a mate of mine who heads a local electronics design company here in Melbourne might be able to knock up something similar. I added a couple of 'wish list' items to the original concept and yesterday he showed me what has been working on for the last couple of weeks in his spare time.
It uses the same Intersil HFA1100's at its core that TSE uses in his design (he researched alternates but concluded that those OP-amps were the best chips appropriate), and has added functionality for variable gain, response curve and setup level. We set the prototypes up feeding a NEC 9PG Xtra that I maintain and the results were very promising. After a short time we were able to pretty well replicate the gamma function of the ATI Radeon 9600 card that normally feeds the projector. It was pleasing to note that the posterization and background noise that normally accompanies using high gamma values in the video card were reduced using the electronics solution. My mate is still fine tuning some of the component values on the board but it's looking like a viable alternative for those folks who don't use a HPTC to drive their projectors.
When I next catch up with him I'll try and remember to take some piccies of the cro traces showing the difference between input and output, but in the meantime here's a couple of piccies of the prototypes sprawled across his "testbench"
Cheers :)
Russ
http://www.users.bigpond.net.au/benn..._proto_01b.jpg
http://www.users.bigpond.net.au/benn..._proto_02b.jpg
post #60 of 492
That's way neater than my test bench! Sent the pcb files off to APCircuits today. Looking forward to recieving the pcbs about wednesday. Stuffing them and testing will happen later. This weekend will be taken up by the gun show in Melbourne. Soon the heat will die down and range time can commence.
  Back to Forum: CRT Projectors
This thread is locked
