Originally Posted by Valence01
I don't know about the remote, but if you're using HDMI for video exclusively, you may be seeing the beginnings of a problem with the HDMI connector. I and others have had issues with leads on the HDMI connector coming loose from the circuit board to which it is mounted. If you have a keen eye and can solder, you can repair it yourself, otherwise you'd need to replace the main circuit board for a few hundred dollars. In either case, you'd have to disassemble the set to some extent. If the problem is with the HDMI connector, other inputs should still work normally.
P.J.
P.J.
I somehow doubt it, as I'm pretty sure I'd be able to notice something like that. Wouldn't it simply hiccup and get all blocky similar to bad reception of OTA HD?
I never seem to have my camera near by when it happens so this is sortof what it looks like:
And it doesn't suddenly cut straight to those streaks, it sort of freezes the frame, makes a popping sound, then slowly fades maybe 2-3 seconds to the streaks. Then it does nothing else until I power cycle. I still haven't tested using the source buttons yet after one of these.
Also remember this only happens the first time I turn it on for the day (its usually on almost all day as I use it as a PC monitor) and then not again until at least the next day.
