Updates...
Its been a slow week due to my helpers grandmother passing away and him having to go to NY to attend the Funeral and Wake. So this week I got the Duct Work installed by a pro (cost $250.00). I Framed out The Platform and Stage by myself this week as well.
I also got my Supplies for the Bass Traps and treatments for the room from BPape which was extremely good priced, he is really working with me.
I am holding Off on doing the Soffits until my helper comes back.
Here are the Cotton Batts for the Bass Traps along with other Stuff That Arrived from BPape. It was allot of Boxes! Boxes were Big but not Heavy, after all its only cotton and fiberglass.
Here is the Duct work that got done. We used Duct board instead of Flex to reduce sound transmission because the Ducts act like a muffler and pretty much kills sound going through it. I already tested them out by placing a Speaker blasting in front of the Duck openings and went inside the home and Heard absolutely nothing coming through the exchanger or supplies. The Ducts still need to be encased and sealed with 3/4" MDF...
Here is the Platform the Chairs will be on, the Platform was built in 2 parts made out of 2" x 12"s and took about 5 hours to make by Myself. It will contain Outlets and Conduits and will be filled with Insulation. The Widow in the Back will be Sealed once all my materials are brought in. The window was a big convinience, saved walking through the house with everything...
Here is the Stage, which will be filled with about 4,000 lbs of sand. The Stage was built in 4 parts which are not tied together yet in the pictures below.
The stage was made with 2" x 10"s and Took about 4 hours to make.
Front View of Stage
This is a Side View of the Room to show the distance between the Stage and Platform
By the way, taking these pictures was impossible without a Wide Angle Lens, I could not Capture the whole side. I forgot I had one, so I ended up using it
More to come Soon...
