From a NHT newsletter.
Scheduled to ship in October, NHT CLASSIC will consist of the following eight models.
Absolute Zero - An ultra-compact two-way bookshelf speaker featuring the output and performance that made the original SuperZero a CLASSIC. MSRP: $200 each.
TWO - A traditional NHT two-way design, employing a 6.5" woofer. Great bass response makes using a subwoofer an option rather than a necessity. MSRP: $250 each
THREE - A completely new design, the Three incorporates a new ¾" aluminum dome tweeter and 2" aluminum dome midrange array combined with a 6.5" woofer in a compact bookshelf model, providing full range performance, wide dispersion and high dynamic range. MSRP: $400 each.
FOUR - The Four tower speaker, though extremely compact in size, features a high-output, four-way system that employs the same dome tweeter/midrange array as the Three bookshelf model with the addition of a side-loaded 10" aluminum cone woofer. The system is bi-ampable, and can be used with NHT's X2 crossover and A1 amplifiers. MSRP: $1800 pair (mirror image).
2C - The three-way 2C center channel speaker employs the same dome tweeter/midrange array as models Three and Four, combined with dual 5.25" woofers. Three-way center channel systems provide better dispersion, less lobing and cancellation than typical M-T-M (mid-tweeter-mid) designs, creating a more realistic soundstage regardless of listening position. MSRP: $450 each
3C - The 3C, like the 2C, is designed as a companion to the Model Three and Four. The 3C features a three- way design, employing a dome tweeter/midrange array combined with dual 6.5" woofers for added dynamics and higher output. MSRP: $600 each
TEN - The CLASSIC Ten is a compact, 10" powered subwoofer with a built in 150 Watt amplifier and aluminum cone driver that is attached to an aluminum former, thereby creating a heatsink for minimal distortion and maximum output. MSRP: $600 each
TWELVE - Similar to the TEN subwoofer, but with a 12" driver and 250 Watt amplifier. MSRP: $850 each
So, basically, a similar design to the more expensive Energy Veritas speaker. The cone probably rings around 4-5kHz, the dome probably around 12-15kHz, so they'd need to get that ringing at least 40dB down. Fortunately, the midbass crossover is at 800Hz, so that should get us down by 45-50dB. On the dome, they're crossover over at 3.5kHz so that would put us down to 36-48dB by 14kHz. I suspect the crossover points are specifically designed to push resonances down below audibility. The tweeter could be crossed over higher, but the dome probably can't. Likewise, the midbass could go higher but not if they want to remove all the ringing, so I'm pretty sure that they specifically chose the points/slopes to deal with it, just as Energy does with Veritas. I guess I'll just have to hear it. I hope they have some in a useful place to hear them.
