Originally Posted by alphaiii
But far off axis it does still suffer from lobing issues, although they occur below 1kHz...
http://www.hometheater.com/content/n...m-measurements
The review doesn't show 30-degrees off-axis, so perhaps the lobing issues are very minor (or absent) there...
Also keep in mind HT Mag typically does their measurements with grills on, and the Stereophile review of the Three shows the grill is fairly detrimental to treble performance... Which is the frequency range where the HT Mag measurements look most different than the Soundstage and Stereophile measurements of the Three.
One advantage of the 2C/3C would be that they're a little more sensitive... and being easier to drive is always a plus.
Still, if I could have a vertically placed Three, I would...
Actually, the measurements you linked are originally from Stereophile and done by Thomas Norton. The original review & measurements were by their former sister publication called Ultimate AV or some such that was geared more for surround systems instead of 2 channel. A lot of their old reviews are now showing up on HTM's site for some reason.
Also, in the very link you provided, it clearly specifies in the first sentence that the grilles were off.
The true, original HTM measurements I was referring to where the 3C bested the Threes are here.
I can probably only squeak about a $500 expenditure right now. I was just getting excited because of the sale prices.
