AVS › AVS Forum › Audio › Speakers › New NHT Classic line to replace Super Audio
New NHT Classic line to replace Super Audio - Page 340
post #10171 of 10233
Originally Posted by Aaron Oppliger View Post
I posted this in the Yamaha A2000 thread, but got the response that "receivers don't include main in's anymore and you should not rely on the evolution X1 for your bass management." What do you say, NHT experts? I love my Evolution setup and just want to make sure I'm getting the most out of it.
Is anyone using an A2000 or A3000 with NHT's old Evolution speaker / amp setup? I just upgraded from an DSP-A1 (which was an AMAZING piece of equipment) to the A2000, and setup is a little different. The DSP-A1 had both pre-out and main in terminals in the back. I'd send the front left and right signals from the A1's pre-outs to the evolution X1 crossover, and then return the signal back to the A1's main in inputs. This allowed the X1 crossover to handle all of the bass management for my speakers / subs.
The A2000 has the font left / right inputs for the multichannel input, but it doesn't look like there's an equivalent for a straight "main in." I'd rather have the NHT crossover handle all of the bass management, instead of the A2000, but it looks like I'm limited to only being able to send the LFE / sub out signal to from the A2000 to the X1 crossover.
If it has left & right front preouts, you could add a two channel power amp.
The DSP A1 was an awesome machine for it's day. IIRC, it was the first to have five.one channel analog inputs.
post #10172 of 10233
Aaron,
Hi, you are much better off running your YPAO and selecting the appropriate crossover in your AVR (it will give you the best blend from subs to mains). I have not used YPAO for a long time (mostly familiar with Audyssey and somewhat familiar with MCACC/Pioneer and Sony's version of EQ).
You still need to use your X1 though as it has the appropriate filters to match the Evolution subs (unlike the X2 which was made for all other brands). I'm also still using as set of 2 W1's with 2 separate X1's (with the 20Hz mod). I use the LFE in, so it is basically a 'volume control' with the appropriate filters for the subs. If you think about it, it's the way most power subs would work - many have the HP/LP crossovers, but they are usually by-passed with using the XO function of the AVR.
post #10173 of 10233
To me, the best thing about them was that the amp or amps and crossover were in different chassis from the sub cabinet, therefore not subject to the vibrations from it leading to a much lower failure rate when compared to traditional plate amps and crossovers.
post #10174 of 10233
I agree with you! The W1's actually had almost no vibration due to the dual opposing drivers, but I still like having the XO and Amps outside the box. My original am I used (Power 2 instead of the A1's) actually failed a few years ago and I went with an Emotiva XPA2. I have not had the desire to change my sub setup yet for that room, the W1's really do fine for its size.
post #10175 of 10233
Thanks everyone for the replies. It definitely makes sense to let YPAO handle the bass management, and I certainly can't complain about the sound I'm getting out of the A2000. It's nowhere near the build quality of the A1, but in terms of features and having the latest audio formats I feel like I've gained more than I've lost. Plus, the A1 will still live out the rest of it's days in our living room doing 2 channel audio for that TV and the occasional bit of music listening (when the kids aren't commanding the TV).
As far as the Evo's go, I run the M5/B5 combo for fronts, with an additional set of W2's for more flexibility with the bass. The X1 has helped to tweak the bass level a bit, since it sounded kind of thin after a multi-point YPAO run.
post #10176 of 10233
Aaron,
Glad you're enjoying your system, that's what really matters. As for the 'thinner' bass, you can simply bring the level of the subs up after you run YPAO. Have fun!!!
post #10177 of 10233
I know this has been a somewhat recent topic of some heated arguing before on this thread, and I hate to be the bearer of bad news here (or good if that happens to be your perspective), but NHT has announced what I view as some fairly hefty price hikes effective on 2/4 that can be seen here. For an example, in 10 days from today the Fours (which are very seldom to never put on sale) will be $2500 per pair, which is really starting to get into a price range with some extremely formidable competition that, frankly, the Fours may no longer fare as well against as it might right now against other speakers in it's current price point.
Maybe the time is soon coming that it might actually be economically viable and feasible to move manufacturing back here to the US even if CA is probably not the right state?
post #10178 of 10233
I would like to find a set or two of the U2 sub system in the Classic gloss black.
Are the Power5 and Power2 ICE amps not holding up?
post #10179 of 10233
I have to agree, they need to do something different. One thing that makes the Classics more expensive is the actual box - the curves (top and bottom of all the satellites) can be made straight again. The finish is also a bit more expensive. I also wish they would bring back manufacturing here in the USA, that would be great. The drivers are still sourced out in Europe, but that's fine. They will be in competition to a lot of others like Aperion Audio and SVS Sound - they just came out with a new series that looks promising. None of them have the low end of the Fours, but that's a moot point when using subs.
post #10180 of 10233
The Power2 was great when it worked. A part failed and was no longer available since the split with NHT and DEQX. I wish NHT was able to keep that alliance or with another like company. They had something good going there. I would love to have a powered, sealed Four with on-board amps. We discussed this before. Emotiva was the best option for the price. The only thing is that their amps are BIG and class A/B (so not as efficient as the ICE amps which run really cool (they are class D based).
On another note, over the holidays I picked up a pair (with the special going on) of the Absolute Walls for my rears (everything in my 11.2 setup are classic based except for the rears which were the new Zeros). The Zeros were moved to another room of course - great little speakers.
post #10181 of 10233
Aperion just had some hefty price increases too... which helps NHT out. The new SVS line certainly looks good on paper..
The curved top/bottom of the cabinets are to prevent standing waves, but alot of very good speakers get away with straight cabinet panels... and the NHT cabinets are solid and well braced (although based on Stereophile's measurements, the AT could use some more bracing of the long side panels), so I wonder how much is really gained in terms of performance... and is it worth it when the cost of the added cabinet complexity and the aluminum rails is taken into account.
post #10182 of 10233
Yes, I do understand the purpose of the curved cabinets. The same with all the older (before SB/ST series) with the slanted front baffle to cancel internal cabinet standing waves - which were also more expensive to make. But, I have to say, at least to me, that I much better like the look of the classic series with the curves and rails. They are audio bling to me and sexy looking. I've check out many speakers and NHT's are still great sound/looks for the price. My wife likes them a lot also (even with the grills off). Will I check out other speakers - well, I'm always looking and listening - I like to check out what's out there. As for subs, I would like to try out SVS new SB1-Ultra (since it's sealed and looks extremely good on the performance side (a bit expensive at $1600 each though). Subs are one area that NHT really needs to work on. I had a pair of Classic 12 subs and was not really impressed and then went with dual W1's, which sounded much more solid (an I still have them).
I'm hoping with this increase in price they are working on updating their series which has not been done since the introduction of the Classic series. Speakers don't really 'age' though since the technology has not changed much over the years, but to keep up with the competition IMO they will need to give a reason for new customers to move to NHT and it has to be appealing enough for those to try them.
post #10183 of 10233
Well I was thinking more in terms of the towers with RAAL ribbon tweeters that can be had at around the $2700 price point from Philharmonic, Selah, Ascend, Salk, etc. much more so than Aperion and SVS when I said formidable competition.
As for NHT's drivers, aren't they Chinese made, NHT designed? I seem to remember a post by Jack Hidley saying as much IIRC.
post #10184 of 10233
The Classic Series is getting a little long in the tooth from when they first came out. Like you hinted at before, a new DEQX series with a tower would be very interesting if it's viable.
post #10185 of 10233
Yea, I enjoyed the last go around about NHT's price increases as it really had staying power. They did explain in their link why their prices went up, and in the end all that matters is the perceived value. As far as moving manufacturing back to the states... I would imagine it still would be less expensive to build them in China.. However perhaps Mexico could be an option, as I remember Polk used to make their speakers down south. As far as California goes, the NHT folks are Cali guy's, so I don't seem them going to Texas or anywhere else for that matter.
I think the classic series is a bit long in the tooth as you say, as this thread started almost seven years ago. When I spoke with a guy at NHT I was told the classic series wouldn't be replaced in the near future, but that doesn't mean that perhaps another line would be released.
Edited by unbridled_id - 1/26/13 at 6:54pm
post #10186 of 10233
Got it! NHT used to have their drivers made by Seas and Peerless (designed by NHT of course), but not sure about their latest drivers.You may be correct and Jack Hidley was always on the money with his info and part of the original designs with the Classic series (and the ones before).
post #10187 of 10233
Forgot to mention on your post about ribbon drivers. They are quick and responsive, but can tend to have a smaller listening window. I do like them but feel that as long as a good driver (type does not matter) is implemented correctly, it will sound great. Look at the Revel Ultima 2 series - very expensive speakers all using aluminum drivers, including the tweeter. If you have a chance to listen to them, they are absolutely incredible in the sound stage they create, very dynamic, and detailed - and very expensive. Also, good horn drivers can be very impressive also (and are usually in speakers that are very efficient - JBL's top of the line Everest is based on this, as are some of the ones that built them in house (small companies) like Seaton Sound and JTR. Again, all about how the drivers are implemented and crossover/box design.
post #10188 of 10233
Vertically yes, but not horizontally.
As for Revel Ultima2s, I now own a speaker, JBL PT800s, that were basically the original version of the current Ultima2 Gem2. The main difference is the the Gem2s have a beryllium tweeter, and the PT800s have a titanium tweeter. The Revel also has a somewhat lower F3, but the JBL has a somewhat higher sensitivity rating. Other than that, the cabinets and the 2 lower drivers are mostly the same, even though the Gem2's cabinets are finished much nicer. Plus the Revels have boundary and tweeter level controls IIRC.
post #10189 of 10233
I figured you knew why NHT chose to go with curved top/bottom panels... and didn't intend for my post to sound like I was trying to explain the purpose to you...
Moreso just stating that while that is the intended purpose, there are some very good speakers that skip on the curved cabinets and still perform very well - Salk Songtower was the first to come to mind, athough that uses a mass loaded transmission line, so maybe standing waves aren't an issue (I don't know).
Either way, I'm wondering, on an objective level, how much is gained by using the curved tops (and bottoms on the bookshelves) with the Classic series... I don't doubt there is a benefit, or NHT wouldn't have done it... but I wonder if it is worth the manufacturing premium at this point. Maybe a refreshed cabinet design, using nonparallel but straight sides would serve the same purpose and be a bit cheaper... I have no idea though.
Personally, I'm not a bit fan of the curved bottom and need for aluminum rails, aesthetically speaking... but that's just a matter of preference. Hell, I don't even like gloss black... but sound trumps looks...
Edited by alphaiii - 1/30/13 at 2:14pm
post #10190 of 10233
You mean like the 3.3s and 2.9s had? If so, it's not cheaper.
post #10191 of 10233
I too am not a fan of having to put the rails on the bottom, though the NHT's curves look nice. I am not sure about curved cabinets costing the same as straight cabinets...
post #10192 of 10233
Well, not necessarily like that. I was thinking more like the new SVS Ultra line, but perhaps without the beveled edges. Like I said, I have no idea what that would cost in comparison to the current cabinets.
post #10193 of 10233
Hi Alphaii,
No worries - I did not take it as an attack in any way. I have not heard any Salks before so can't comment on them (I would like to hear them though).
I do like the curved cabinet of the Classics just because I do then they look sexy and I also prefer the gloss black. I also appreciate other finishes - some are just wonderful works of art. I'm not sure of the actual true benefit of the curves, but it makes total sense that it would decrease internal standing waves. Also, curves can be more rigid which would also help. I've owned NHT's since the original Super Zeros / Super Ones. I then went to the 2.5i / 1.5i with center (couldn't afford the 3.3's, though they had and extremely good bottom end for a full range speaker). From there I went with the ST4 / SB3 series (with matching center and sub). They just sounded a bit better than the 1.5's. I though I would just stick with them until John brought in the Classics. We did some listening, comparing them to the ST4's, 2.5i, and other NHT's. We were actually blown away since we were not expecting that much of a difference. Anyway, they just threw a HUGE soundstage - usually not found in towers. I was sold on them right away and sold my whole NHT collection in exchange for the Classics. Did I compare them to other makes/models before - yep. John at the time also sold Revels, PSB and JM Labs. He also had a lot of recent trade-in's from B&W, Genesis, Infinity, etc. So it was easy to do comparison tests in the same room - level matched with the same electronics.
Now, are the Classics the best for their price - well there are many speakers out there that are pretty incredible also. As for comparison to other NHT's, I actually think the Evolution (M5/M6) were the most forgiving of any room. As for the subs, I did not like the Classic subs (had two of the Twelves) and went instead with two W1's. As for the best sounding NHT - that would be the Xd's, they were absolutely incredible - but did not pass the WAF - my wife thought they were UGLY... He loves the looks of the Classics and actually preferred the towers for the front saying they 'looked' more balanced.
As for the best speaker that I've actually heard - that would go to the Revel Ultima Salon2. Absolutely incredible imaging, definition, and detail. But- WAY out of my budget. I also like a lot of the JM Lab series (although not their looks). B&W's to me look really cool (listened a lot to the 802Ds and some of their other Diamond line) but something about them just didn't set well with me - the mid-range was just not to my liking. I know they are incredible speakers and a lot of owners here at AVS that own them. I guess each to their own. Speakers are really subjective compared to any other part of the audio chain, both in looks and in sound. They also have to fit within a person's budget and room needs (lots of my friends are very happy with a simple HTIB or speaker bar).
Enough ranting...
post #10194 of 10233
Interesting! They are the same company - Harman International. One speaker I would like to hear are the Everest (ugly to me but I bet pretty impressive sounding). I've always had a place in my heart for JBL's since I first heard them back in the late 70's. I've owned several different pairs in the past.
post #10195 of 10233
Hi Alphaii,
Enough ranting...
Perhaps now that they raised the prices they can offer the 30% off gift card deal again. I waited for it this fall and it didn't come out. But the next pair of speakers I get won't be NHT's either way.
I remember when the M5's were getting blown out for a real nice price. I wonder what a pair of those would have sounded like..
http://www.nhthifi.com/ServiceCenter/Evolution-M5-monitor-vintage-nht-speakers
Edited by unbridled_id - 1/30/13 at 8:43pm
post #10196 of 10233
They were pretty impressive along with their wall mountable version. We set up a whole system in my brothers house with them in his main listening room. The other rooms used the Classics and KEF (two separate rooms).
post #10197 of 10233
Would you take a pair of the M5's over a pair of classic 3's ????
post #10198 of 10233
There are other brands that had a slanted baffle like the new SVS Ultra. Thiel comes to mind and they sounded pretty good. The slanted baffle was suppose to help with time alignment, not sure if that is the case with the new SVS. I would really like to hear them.
post #10199 of 10233
Did NHT tell you this or is this your opinion ?
post #10200 of 10233
Unlike you, I never espouse opinions unless it actually is an opinion, which this clearly was not. I also realize that you seem to have a problem with doing your own searches, but do one (and don't ask or demand that I do it for you because it's not going to happen), and you might find the explanation of why the Evolutions went to the VFIG over the FIG of the Music Series.
Also, keep in mind that the 2.9 was $2500 15 years ago, which is what the price of the Fours will be on Monday. The T5s were also $2500 10 years ago, but included the X1 and A1.
  Back to Forum: Speakers
