Originally Posted by zaracsan
I would have preferred to have seen dual sub outs on the Controller for my dual U2s (4 W2 cabinets), but as it remains an unknown whether the BM in the Controller is so much better than when running through the X1, that it may be premature to be bumming about it at this point. With the X1, we also have the additional benefit of knowing we can mod it to go deeper if we choose to, and I'm not sure whether that would even be an option on the Controller. No doubt, there are tradeoffs with either approach.
If I get the Controller, I will be very interested to compare the two different sub connection options. My hope would be that electronics in the Controller are so much cleaner than in an X1, and when combined with the advantages of the DSP, make the tradeoff of giving up the X1s tweakability and stereo bass potential worth forgoing. Stereo bass is a debateable advantage, and with my M6es being able to go down to 61 Hz, this may be less of a problem than other NHT speakers with less bass extension. At this point, we really are speculating here.
It looks to me like they could have a simple software upgrade/revision on the pre/pro if they really wanted to to boost Evo subs output down to -3 db at 20 Hz.
You may have a point as I have also wondered myself just how much advantage there really is to "stereo" bass if you have the high pass crossover low enough.
On the Fours though, with the crossover to the built in subs being at 125 Hz, IMO that's just too high to get away with using a single A1 to bi-amp with in conjunction with a X2.
