B2R,
I don't know about compatibility between the 2C/3C and the AC-2. I have to run some acoustic phase measurements to determine this.
The 2" domes in the M-80Xd are the same driver with a different voice coil impedance as used in the Classic series. I wouldn't use an M-80Xd for a center channel with anything else but itself for Lefts and Rights. The M-80Xd gets processed by an XdA which has about 8ms of latency in it. You're going to have a very hard time getting your other channels time delay to match. The dispersion of the M-80Xd will be considerably narrower than any of our consumer speakers. This will make it very hard to match the tonality of it to anything else. The 3C has about the same output as an AC-2. I don't see why anyone would need any more than this unless their room is just huge. Of course if you really want a headbanger/hi-fi HT system, you can buy 5 M-80Xds and a couple of S-80 subs to go with them. Be prepared to bring a pretty fat wallet though
Ten 8" magnesium cone woofers, ten 2" dome midranges, four 12" long throw woofers, 4kW total amplifier power, etc, etc.
We tried to minimize height and depth in the design. This means that they get longer.
