Balancing RGB takes experience and really is about learning the art of science.. It is not just about following the dancing bars and dots - which ColorFacts also has BTW. The pretty pictures tend to make the newbie think it is easy - and I don't doubt that the software vendors want you to think that!
The first thing I do is find the clipping points. Usually for DLP this is Red for gains and Green for offsets. Then I work my way back to the target using the other colors. Knowing that luminance Y is mostly Green - if you do the gamma math you can balance out your gamma curve at the same time as grey scale and doing the clipping check maximizes contrast at the same time. Also knowing that dE is a perceptual error - you can try different moves on the target and see which has less perceptual error if you cannot make things perfect. Other technologies (LCOS, DLP, CRT, plasma) will have different natures - and it requires experience on those technologies to see what works best! LCD tends to have S shaped gamma curves, LCOS tends to be blue limited, CRT usually never has a flat blue across greyscale - and I am sure plasma has something wierd about them too - but I have never done any. When you cannot make it perfect - like all engineering fields you have to learn how to make acceptable compromises.
Combine that with what Bob is learning now - you have to understand the nature of your instruments and the compromises made in making them affordable - and figuring out how to use them for best accuracy, speed, and reliability.
