Originally Posted by sycamore
I know you guys have beaten this to death but I just have this question. I'm using indoor antennae for OTA HD channels. However, the TV guide hasn't worked at all. I have tried unplugging it overnight. To test whether my stations are sending out guide signals or not, I used a STB and connect that to my TV and it indeed showed the show info on my STB. This confirms that the stations does send out info, just that my TV guide wouldn't pick up. Helps are appreciated, thankx!!
Is PBS present among the OTA stations you receive on your antenna ? If not, you will likely not get TV Guide info since PBS is the most common distributor of this data. Also do not unplug the TV, just turn it off and leave the OTA antenna connected.
. Two days ago I turned on the TV when I got home, didn't have any favorites, so I reset them. Yesterday when I got home they were gone again.
