I thought I would share some info that may help you calibrate your 1080P Samsung DLPs. After reading a number of posts, I decided to change the gamma to 0 from 2 and then set the picture to Standard and Warm2 which one poster reported was the closest to D65 based on the ISF who calibrated his display. However, with those settings, my display had a green tint to it. I then decided to enter the service menu and look at the CCA and CCA (on) menus. After a few minutes I figured out what the x, y, Y settings were for and, more importantly, where I could get the values for those settings.
I decided to downloaded a program from Babelcolor and proceeded to get the x, y, Y values for Red, Green, Blue, White, Cyan, Magenta, and Yellow for a number of different working spaces including CIF HD, NTSC, SMPTE 240M, SMPTE C, and sRGB. However, the Y values were very low compared to what the initial settings were in the Samsung, however, all Y factors seemed to be off by a factor of about 4. Then it dawned on me that Y is sampled 4 times, so I multiplied the Y by 4 to get the Y values for the CCA menu. The most important info here is that the CCA settings on the left are for STD color space and the ones in the middle with the D in front of them are for HD color space.
The person who got their TV calibrated professionally also mentioned that the Cyan setting was way off and the Magenta setting was also off by a good margin with yellow only being slightly off. When I looked at the values I got for Cyan, Magenta and Yellow from the software and compared them to the values in the Samsung that is exactly what I found.
I cant tell you that this will make your display 100% calibrated, but I can say that when I compare the colors on my HLR to the HLN that I had calibrated professionally they look nearly identical if not identical. I can now say that I am completly happy with my Samsung, at least until I have to call for service. I have attached an excel file with the x,y,Y coordinates for various work spaces. Hope this helps you DIY tweakers.
Color Settings.zip 3.4609375k . file
