Originally Posted by slimoli
I have a question for everybody:
I am in my second set (72927) with EXACTLY the same problems I had with the first one. The 2 major problems I have:
After power off the settings and format on tuner-1 (contrast, brightness...) sometimes are lost and become whatever the settings are for the last used input before the power off.
The most annoying problem, however, is the "sound and no picture". Almost every day I have to do a system reset because when I power the TV on I get no picture. The sound is fine and all the commands apparently work. I can see all the OSD information and even the guide displays fine but no picture from ANY input comes up. I tried to unhook devices using HDMI, since this was the first guess from a Mitsubishi engineer in California, to no avail. Only one other board member posted identical problem with a 62628 set and he also lives in South Florida. My TV-GUIDE has never been turned on again after a initialize and I thought the problem was over but today I had the "sound and no picture' again. I can do a system reset or unplug the TV to restore the picture but this is really annoying. I can return the set again but other brands/model is no option since my wall unit has been custom made for it. I also have to admit that I love the picture when it works.
Any suggestion?
Sergio
Any suggestion?
Sergio
The two 52628's I had, had a similar problems except it was Picture with no digital sound on digital stations only................my dealer (who had already seen this problem before - buggy software again), knew the fix...............instead of doing a reset or reinitialize.............unplug the set for an hour and half, then plug it back it in................that may fix it, and save all your settings. I had to do that twice with mine when it lost sound. Worth a try maybe?
