Originally Posted by
EWL5
There are a couple of things that may be in the way of your 1080p/24 connection:
1) A receiver is in b/w that does not pass the 1080p/24 signal.
2) Your 930 build date is closer to when it first came out.
Like you, I have failed to get the 1080p/24 from my PS3 to my 1130 but it may be because of my plasma build. NemoZorro has the same TV as me but his plasma is newer than mine.
That is correct. My guess is that they started including the feature in the later panel builds in order to "test" it for the 7gs around the corner.
It will definitely say HDMI, and the screen setting, like FULL, but list no resolution if it is working properly. I am using a Pioneer BDP-HD1 player with it set to source direct, and the only setting on the panel is Pro Cinema is ADV. Others have noticed this too, but it could simply be that the later panels have them.
I have also confirmed this with Pioneer support; they are certainly aware that the feature exists, just that they won't support issues with it as it wasn't a listed feature.
Try an HDMI cable directly to the panel from your PS3. If that doesn't work, like EWL5 said, it is probably a build date then.
