Originally Posted by caesar1
I've read every page of this thread, but I'm still not clear on this one issue:
Does the Elite (50 inch) have any really noticeable picture quality improvement over the 5060 -- or is it pretty much the same?
If so, what is the advantage of the "Elite" (other than bragging rights)?
Can I throw out a theory? I suspect the actual panels are exactly the same. The differences between the two are largely in the level we are able to calibrate them, or additional flexibility in processing options with the Elites. I suspect those differences are found in the media receivers. Whether those differences are simply a firmware difference, or whether there is a hardware difference is a good question, and one I would love to know the answer to. If it's a firmware difference, you can see where I'm going with this.
Anyway, addressing your question more directly, if the differences between the units are in the ability to fine tune each panel, I would expect real world differences to be relatively small. Then again, for some folks on these forums, it's those small things that mean the world...so it's all relative.
