AVS › AVS Forum › Gaming & Content Streaming › Digital Recorders (PVRs) General › How do I hook up a dvd recorder to the Motorola 6412?
post #1 of 5
I just purchased a Lite-on dvd recorder because I wanted to permanently save programs recorded to my dvr (Motorola 6412). How are people setting up a dvd recorder with this dvr?
post #2 of 5
If you're not using the S-Video output (or Composite Video output) then you should be able to output a 480i signal to the S-Video input on your DVD recorder. I think the 6412 only has one set of Audio Output jacks so you'll probably have to split these to run to your TV and DVD player.
post #3 of 5
Thanks for the reply! It has a rca video out as well as an S-video, so video isn't the problem. It's the audio since the 6412 only has one audio out.
Can I split the audio output using a y-splitter? Is there any other solution to splitting the audio? This will probably hurt sound quality as well. I guess I could remove the y-splitter for when I'm not recording shows. I only want to save recorded shows stored on my dvr. I have no interest in recording shows live from the 6412 to the dvd recorder.
I wonder if I could temporarily hook up the audio out on the 6412 to the dvd recorder instead of having audio out hooked up to the tv. I wouldn't get any sound from the tv from the dvr while recording, but I should be getting sound to the dvd recorder from the dvr to record the shows.
Thanks again!
Chris
post #4 of 5
Update: I got it worked out. Since the 6412 has more than one video out, but only has only one set of audio out, I bought a set of decent quality monster audio rca 1m 2f y-splitters, so I could split the sound from my tv and the dvd recorder.
I originally unhooked the audio from the tv and hooked it up to the audio on the dvd recorder, but I had to have the dvd recorder turned on and watch tv through the dvd recorder's tuner in order to get sound.
Thanks again for you help.
post #5 of 5
how is the picture quality via s-video? is it worse then original DVR recording?
This thread is locked
