Originally Posted by
bboncorr1
from the bottom of the tv to the bottom part of the screen it is 7 1/4 inches.
half the screen from top to bottom is 12 1/4 inches.
so you answer would be approx. 19 1/2 inches.
if you dont mind im a little curious to why you need those measurements.
Thanks much. The reason I needed this info. was to determine what height stand I need, compared to my current lousy stand which is holding a nice XBR800 LCD RPTV.
The XBR800 has a pedestal base, whereas the SXRD doesn't, so I know I will need something higher, (even this TV does), which is fine as I have looked at many stands, and they are all higher now than they were 3.5 years ago.
I just measured my TV, and it appears only to be 4.25" taller, so I can get the stand I want now, and it will be fine until I get an SXRD.
Seeing as I already have a 50" 16:9 TV, I didn't really need the full measurement, the screen height is the same. I really just needed the 'below screen height', but I just thought of that.
