Wow - wish I had read this thread before installing my 106 electric tab-tensioned. It did indeed take a while to figure out the proper bolt usage. I had to remove two washers to get things to work out. Used two massive lag bolts straight into the ceiling rafters. Yes, it is heavy, but it can be installed by one person
Okay, now it's up, and with my Panny AE900 I think the gray screen is too dark. Directv HD is almost unwatchable for shows like Law and Order or anything with night scenes. I have the bulb set on high, which should be unnecessary. The brightness is still set at the factory default.
I originally was just going to go with the pj/screen, but because the screen blocks some cabinets when down and my rooom has some day time ambient light I am also going to add a 61-inch DLP. Therefore, the pj will likely only be used at night in total darkness.
Should I go for the matte white? I wonder if Elite will make a reasonable swap? Any input would be appreciated.
I will also consider selling the Elite and going for a Dalite high power, which seems to be a favorite around here.
.Okay, now it's up, and with my Panny AE900 I think the gray screen is too dark. Directv HD is almost unwatchable for shows like Law and Order or anything with night scenes. I have the bulb set on high, which should be unnecessary. The brightness is still set at the factory default.
