Originally Posted by presenter
Greetings, I thought I would weigh in, since as some have mentioned, I liked the gray in my review. Generally grey screens take some getting used to. And if you have a projector that's not particularly bright - such as the Z5, yes you will likely not run it in best mode, to get the lumens.
But more to the point, I believe some of the confusion comes from "which screen is which". To my best understanding, the Cinetension and the fixed wall - the ezFrame (I reviewed the EZ frame), have a newer, and definitely much lighter gray surface. In addition, it really isn't very "High Contrast". It is a combination that I really like.
It's no match for my Firehawk, and lighter gray to boot, but I found using it pleasing with all but dim projectors, and not even bad there. I suspect that those of you saying its pretty dark, have the older versions (without the 1), or have a pull down? I reviewed the ezFrame back in August and the surface was pretty new I believe. I don't know what they were putting into the VMAX or other motorized, but I'm pretty sure the pulldowns did not have it.
Hope that helps a little... I wouldn't bet the farm that I got everything straight here, but I'm pretty sure those not happy with their grays, do not have the fabric that is on the ezFrame I reviewed (R100H1, if I recall correctly).
Biggest problem is that picking screens is more subjective than the projectors, and tougher to choose.
-art
-art
I see you are reviewing the Sony Pearl (VW50). I just bought one and I am trying to find a 106" screen for it. Do one of these Elite screens go well with it or should I go for a more expensive screen like a Dalite? Your best recommendation for the sony?
thanks,
