AVS › AVS Forum › Display Devices › Display Calibration › projector cal. help
projector cal. help
post #1 of 3
How would I go about calibrating a Runco Projector myself. I would like to find out how certain adjustments are intended to adjust the picture. Any help would be deeply appreciated.
post #2 of 3
Greetings
Depends on what you want to adjust. Runco digital projectors can typically adjust the grayscale in the service menu. Contact Runco for the Access codes.
Regards
post #3 of 3
Originally Posted by Michael TLV
Greetings
Regards
I want to adjust gray scale & color. Some of the settings aren't what I am use to such as what des "White" do? What does "filter" do? What color temp are the different settings suppose to be. I think their are 4 of them and I can't find out which one is 6400K etc. These are all in the user menu.
This thread is locked
