AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Hartford, CT - Comcast
Hartford, CT - Comcast - Page 8
post #211 of 3209
Originally Posted by PMJohnson9 View Post
Hello all! This is actually my first-ever post here, but I've been lurking for some time now on this thread and on the Sony SXRD threads...
I am soon moving into Pawcatuck (I assume part of the Groton Comcast area) from Rhode Island where I have had Cox service. I will soon also be new to HD when I get off my butt and buy my first HD TV.
What I am wondering is what you all feel to be the pros and cons of Comcast with HD versus getting the Dish Network. I've briefly looked at both websites and it seems the Dish has a slightly better HD lineup, but I've never had satellite before so I'm not sure which direction I should go. On another note I have also read some horror stories regarding the Comcast internet service, so I'm a bit concerned there as well...
Any advice would be appreciated as I have never done business with Comcast before wherever I have lived.
The major disadvantage of Dish or DirecTV is that you have to use an antenna for the local channels in HD. They also require a commitment which Comcast doesn't. DirecTV is supposed to start providing CT locals in HD in April. I would start with Comcast and then check out DirecTV once they have the local HD available.
post #212 of 3209
Originally Posted by Agnt86 View Post
Well, lets run your numbers. We've got .6mhz per digital and 3mhz per HD. So with the 85mhz remaining, you could do 141 digital streams or 28 HD streams. Its probably a kind of system that can allocate based on what's needed at any time - not a hard split - so its hard to tell. But in either case, it seems reasonable. I mean, given the service areas, it sounds like that could be a reasonable number of people using the system at the same time. Maybe its more efficant, but if you double the numbers it still doesn't sound too unreasonable.
The only thing I could think you might be missing is Out of Band communications. The talkback/data download for the cable boxes and other such devices. Does that use the regular channel bandwidth, or is that taking up space on the wire somewhere?
Note the "?" next to OnDemand/On Demand HD though. It's possible that that is soaking up the rest of the available bandwidth on the 750mhz systems. I don't know how that works, but I would assume it's a single stream of digital or HD depending on what you're watching. At least it seems logical to me, but from a technical standpoint I don't know for sure. If it truly is a single stream then it doesn't explain what the rest of the bandwidth is being used for.
post #213 of 3209
I think its likely a single digital stream or single HD stream, but I would think it needs to be a stream per person using the service at the time. Because each person is watching something different or controlling it different ways (pausing, RR, FF, etc).
I bet it uses up a whole bunch of bandwidth. But, I could be TOTALLY wrong too .
post #214 of 3209
OH MY! I am speechless. The DD logo is not present, yet, verified with status screens.
ADS
2 WFSB (CBS)
3 CN8
4 WVIT (NBC)
5 LOCAL *
6 WTIC (Fox)
7 WEDH (PBS)
8 WTNH (ABC)
9 WCTX (UPN)
10 WHPX (PAX)
11 WTXX (WB)
12 WGBY (PBS)
13 WRDM (Telemundo)
14 HSN
15 NSCN
16 TBS
17 EW//NJ
18 WUVN (Univision)
19 EDU ACCESS
20 CT-N
21 GOV ACCESS
22 CSpan
23 CSpan 2
24 AMC
25 OLN
26 TWC
27 Travel
28 NESN
29 ESPN
30 ESPN 2
31 FSN-NE
33 Golf
34 FX
35 TNT
36 USA
37 Court TV
38 Hallmark
39 Lifetime
40 ABC Family
41 Nick
42 Disney
43 Carton Network
44 Animal Planet
45 A&E
46 History
47 Discovery
48 HGTV
49 Food
50 TLC
51 TV Land
52 Sci Fi
53 Spike
54 Comedy
55 E!
56 MTV
57 VH1
58 BET
59 FNC
60 CNBC
61 HNN
62 CNN
63 MSNBC
70 QVC
71 Shop NBC
95 TV Guide Channel
96 Local Access
98 Shop At Home
99 PIN
NO ADS
32 YES
97 WEDH
* Black screen
Revised 2/14/06
Wonder why YES is not in ADS. WEDH seems to be a dupe.
post #215 of 3209
ADS
2 WFSB (CBS)
3 CN8
4 WVIT (NBC)
5 LOCAL *
6 WTIC (Fox)
7 WEDH (PBS)
8 WTNH (ABC)
9 WCTX (UPN)
10 WHPX (PAX)
11 WTXX (WB)
12 WGBY (PBS)
13 WRDM (Telemundo)
14 HSN
15 NSCN
16 TBS
17 EW//NJ
18 WUVN (Univision)
Did these just show up today as ADS??
post #216 of 3209
I woke up at about 1:30 AM and decided to flip through the channels instead of watching the olympic coverage I had seen earlier. I noticed that the picture on the channels looked better. As I did not see the Dolby DD (it has since appeared on a few more channels) I would move up the channel lineup, power off the box and hit OK for the menu and verified that all the channels wth the exception of YES and WEDH (which is a dupe of an ADS channel) are all broadcasting in 256 QAM.
I was shocked as I did not expcect to have 99.9% of the analog channels in ADS.
On another note, channel 5 is no longer a black screen, it is back to the Community BB, complete with DD logo.
post #217 of 3209
Wow - still analog here in Windsor for all channels (except for digital simulcast on locals in the 80's)
post #218 of 3209
I just noticed some of my channels tuning slower on my TV with the CableCard, which is usually what it does for digital or HD channels. I popped into the diagnostic menu, and confirmed that it was tuning a digital channel. It appears we also have ADS happenning on the Plainville system! To the best I can tell, here are the channels in ADS right now. All are QAM256.
2 - CBS
4 - NBC
6 - FOX
8 - ABC
9 - UPN
10 - WHPX
11 - WB
13 - WDRM
18 - WUVN
22 - C-SPAN
42 - Disney
70 - QVC
99 - HSN
The locals/broadcasts made sense, but some of the other channels seem kind of random. C-SPAN but not C-SPAN2? QVC and HSN but not Shop at Home? Disney?
post #219 of 3209
I feel like an idiot. What does all of this mean? What is ADS? What is QAM256? And where are you seeing the Dolby DD?
post #220 of 3209
No problem - I didn't know at first either.
ADS means "Analog Digital Simulcast". That basicially means that they are taking some, or all, of the current analog channels (channels under 100) and broadcasting them again in digital on another channel. This is part of the transition to get rid of the analog channels, which are using up over half the bandwidth on the cable.
QAM256 is how the signal is being transmitted. QAM stands for Quadrature Amplitude Modulation. There are other QAMs, like QAM64, but the goal is to get everything on QAM256. The higher the QAM number, the more bits you can push. Note that QAM is just how the channel is sent to the home - it has nothing to do with what video/audio scheme is used (MPEG2, Dolby Digital, etc).
I don't know where they are seeing the Dolby DD. My guess is on the on screen display somewhere. I don't have an HD cable box - I use a CableCard TV - so I don't see it. I dig my information out of the TV's CableCard diagnostic screen.
post #221 of 3209
Thanks for the education - useful information.
post #222 of 3209
I'm in East Hampton CT (Comcast) and would prefer to use a cable card rather than a set top box since I'm not interested in PPV or On Demand. Comcast says that it won't install cards now and is waiting for some unspecified period until Motorola provides "newer/better" cards.
Any news or experience you all have?
post #223 of 3209
The Dolby D is on the flip/info bar when changing the channel or hitting the "info" button.
post #224 of 3209
I think they are just giving you a hard time about getting one. I'm on the Plainville Motorola system, and got my card about a year ago. My friend is on the Middletown Scientific Atlanta system, and just got a CableCard installed last month.
You might want to call up and try pushing them a little harder about it. See what they say/do.
post #225 of 3209
YES Netwrok is now ADS, we are 100% digital.
post #226 of 3209
Thanks for the suggestion. The tech is coming out Friday (tomorrow) morning.
post #227 of 3209
By the way - PPV does work with CableCard. You just can't order PPV from the TV, or on demand. But if there was like a boxing or wrestling, or some kind of event at a scheduled time on one of the PPV channels you want to watch, you can call up and order it.
post #228 of 3209
Thanks for that info.
BTW, the tech couldn't get the Scientific Atlanta card to work after 1.5 hours and three calls to Comcast tech support. The card is recognized by the Sony, but the TV won't download any channels. Naturally, the TV was blamed. Sony provided telephone tech support without results and recommended a local repair shop. They couldn't find anything wrong with the TV or card reader and think it's the card. I'm waiting for Comcast right now.
Any similar experiences out there?
post #229 of 3209
I finally had the chance to check my area for ADS as well. We're now 100% digital on the Plainville system.
That makes Harford and Plainville. Can anyone else verify the other systems as well? I'll update the spreadsheet in the first topic tomorrow to add the latest info.
post #230 of 3209
I still only find those listed below here in Windsor:
Originally Posted by cheneyp
I surfed the digital channels and found the following:
Simulcast
80-2 WTXX
80-3 Univision
80-4 WVIT
80-5 UPN
80-6 WFSB
80-8 PAX
80-9 Telemundo
80-11 WTIC
80-12 WTNH
Others
93-10 On Demand Previews
94-6 Fuse
post #231 of 3209
Simulcast
80-2 WTXX
80-3 Univision
80-4 WVIT
80-5 UPN
80-6 WFSB
80-8 PAX
80-9 Telemundo
80-11 WTIC
80-12 WTNH
Others
94-6 Fuse
Did you do a new search with your qam tuner to see if you picked up new ones? They won't just appear as they're added, you'll need to actually add them.
post #232 of 3209
I did but maybe I didn't go through all of the possible sub-channels on my TV QAM tuner - it does take awhile... I'll check tonight
post #233 of 3209
Could it be possible that the extended basic digitals are encrypted?
post #234 of 3209
Quite possible. I assume you are finding your ADS channels on your Comcast box so you don't offhand know what digital subchannels they are on?
post #235 of 3209
That's correct, using an STB.
post #236 of 3209
I'm on the Plainville system and can confirm these results. In my previous post we were partially ADS, but we appear to be pretty much fully ADS now.
I only see one analog channel left. Its channel 97, WEDH.
post #237 of 3209
OK - I checked last night and found several more ADS channels on my TV:
81-10 CN8
81-7 WGBY
81-11 EWTN
81-1 CTN
I did find 2 shopping channels - I assume they are HSN and QVC but since I don't spend a whole lot of time watching these, I didn't much care to note where they are...
Still have more searching to do - ran out of time last night...
Now at least I can remap my HD DVR to these channels instead of the analogs for better rec quality (when I am forced to record SD!)
post #238 of 3209
WEDH on 97 will not be ADS as it is a duplicate of WEDH on channel 7 which is already ADS. For some reason they did not place this duplicate with the ones in the 700's marked as Local Access.
post #239 of 3209
Am I the only one not able to receive WGBY on Comcast channel 12 or CT Network on channel 20 in West Hartford?
post #240 of 3209
No bandwidth my arse!
Today, or yesterday, Comcast put the programming back on INHD2. They did not remove Universal HD.
InHD, INHD2 and UHD are all broadcasting in HD. Where's this lack of bandwidth? Lying bastards!
