AVS › AVS Forum › Display Devices › Display Calibration › New calibration disc
New calibration disc - Page 13
post #361 of 2211
Originally Posted by Vern Dias View Post
Ditto.
Vern
OK, I'll consider keeping them if someone can give me a short, simple (As possible) write up on what one would use these for. I'm the one who will get the questions. I don't believe they fit the spirit of the disc. What would be nice is a gamma test pattern, becasue that *is* something you can adjust, but I don't know how to make one. My instruments tell me the gamma when I run a grayscale.
Its not that I don't appreciate having the freq. patterns, I do, but if they don't do something specific, explainable, and useful (without a oscope)... they are on the chopping block...
FYI, Here's the description from the pattern author (drmpeg): They are "frequency burst patterns".
In order of presentation on beta 4.x:
#1
alternating white/black pixels with the first
bar 4 black/ 4 white pixels, second bar 3 black/3 white,
third bar 2 black/ 2 white and the last bar 1 black/ 1 white.
In other words, they are 1.6875 MHz, 2.25 MHz, 3.375
and 6.75 MHz resolution "patches". I believe the 6.75 MHz
"patch" can be used for 1:1 pixel testing, but I'm not 100%
sure.
#2
sine waves of frequency (in this arrangement)
0.5 MHz, 1.0 MHz, 1.5 MHz, 2.0 MHz
2.5 MHz, 2.75 MHz, 3.0 MHz, 3.25 MHz,
3.5 MHZ, 3.75 MHz, 4.0 MHz, 4.2 MHz
4.4 MHz, 5.0 MHz, 5.5 MHz, 6.0 MHz
The higher frequency sine waves have lot's of sampling
phase error, which is unavoidable. On Avia Pro, they
use frequencies they are integer divisors of 13.5 MHz
to avoid the problem. I think they are called "Nyquist"
bursts..."
S
post #362 of 2211
Originally Posted by Danabw View Post
Is anyone willing to post a little "how to" for the most significant sub-set (black level and ?) of adjustments I can do w/this disc?
I haven't read it but this thread:
http://www.avsforum.com/avs-vb/showt...&&#post2852401
looks to be along the lines of something to get you going.
When looking for instructions, functionally speaking my disc is closer to DVE that Avia becasue it has "blacker than black" in it's patterns, and thus has similar gray ramps. They are using DVE in that thread and the guy posted screenshots I think FWIW. I know DVE has some instructions of sorts on their website, look under the DVHS tape version section. Their website is more difficult to find stuff on than their DVD , but it's there.
post #363 of 2211
#1
sure.
#2
bursts..."
S
They were patterns that I had already created, so I just sent them off to you. If you'd like to delete them from the disk, that's cool with me.
The sine wave bursts were created to validate MATLAB simulations of the 720 to 544 polyphase horizontal filter in the new MPEG-2 encoder for the DCT-6412 Phase 3 cable box. The cable specification requires the video passband to be flat to 3.75 MHz. Here's the measured results of different tap sets.
Ron
post #364 of 2211
Thanks Ron, that's interesting stuff. I didn't think you'd care one way or the other if the frequencey patterns were on the caldisc. Your use of the patterns sort of reinforces what I was saying though, for a normal calibrator, not looking with scopes and MATLAB, the patterns are just cool to look at, but provide limited information from just viewing.
CHeers, Scott
post #365 of 2211
I too would like to request a "how to use it for dummies" tutorial. I recognize that this thread is designed to help the development of the disc, but, there are obviously a lot of people who are not technically competent in this field but can follow instructions and want to benefit from the knowledge and effort that has been put forth by those who are competent. From a standpoint of a non techie, this seems to have the potential to be the best disc available anywhere. Some of you are certainly capable of putting together a useful and user friendly set of instructions that start right after "turn the projector on". Having followed this forum for some time now, I know that a lot of people simply like the opportunity to help and those that don't are in the minority.
post #366 of 2211
THanks, Scott. That does look like it could be a useful thread...I'll also go back to the DVE site and search again...thanks for the specific pointer to the DVHS tape section.
It actually looks like someone could take the thread Scott posted above and do some copy/edits w/references to Scott's DVD and have a good set of how to's w/out too much work. (Or should I say ). In the meantime I'll continue on in self-help mode.
post #367 of 2211
Aha...not sure why it didn't turn up on my last google, but this page has some how-to info...has info on AVIA and DVE discs. A start...
http://www.ramelectronics.net/html/V...libration.html
post #368 of 2211
Second Aha! DVE how-to PDF here:
http://www.videoessentials.com/Manuals.php
post #369 of 2211
post #370 of 2211
Since you ask, this is what I meant:
http://www.videoessentials.com/D_Theater_signals.php
also short snippet:
http://www.videoessentials.com/resou...alibration.php
Much gracias!
post #371 of 2211
GetGray,
I recently downloaded and burned the 4.2e file. However, the intro screen says Beta 4.2b. Is this just a typo on the intro screen, or might I have done something wrong? Thanks!
P.S. I used Nero Express 5.5.10.68 which seems to work fine.
post #372 of 2211
GetGray - Are you monitoring the caldisc05@calibrate.tv email address?
post #373 of 2211
Originally Posted by catnip911 View Post
GetGray,
It is a type on teh opening screen. If you go the right zip file, then you are good. My apologies for not paying better attention to those little things, I've concentrated on the patterns without the corresponding main window update for beta 4. Hope to get beta 5 out soon then wrap it up with the real thing ver 1.0.
post #374 of 2211
I am, but I've been out of town since yesterday afternoon, just getting back. I have a few pending, I'll get beta accounts setup for them and get them out first thing tomorrow morning.
post #375 of 2211
Sailor Bill & Danabw -- I am working on a brief set of instructions for Scott's disk. They will (?) be included in the Version 1 release (I hope). I have made them available only to Scott and a few others, for editing purposes. Since the details of the GetGray Calibration disc are still in flux, these have not been available in general, since its a "work in progress".
These instructions are not all that detailed but, along with the AVIA &/or DVE information, should provide enough instruction to provide a some guidance as to how to use the disc.
post #376 of 2211
All:
Beta 4.3 is avail for download on the site (www.calibrate.tv). The original 4.2 was really meant to test navigation. Now, 4.3 represents wrapping up and finishing polishing all video patterns including those done through the 4.2x versions. All patterns have now been re-encoded with no mpeg filtering, no offset, etc. All color-critical images have been redesigned so color boundaries fall on 8x8 blocks. All of this was to minimize mpeg artifacts. This re-encode should have cleared up any issues with the freq. patterns, maybe Vern and/or Ron can have a look for us if they have time. I've re-encoded as the pattern author (drmpeg) advised. I also flagged then as 4:3 native DVD aspect to ensure no artifacts were introduced from stretching them to 16:9. Some player don't auto-obey the 4:3/16:9 flag, some do. It might not make any difference, I haven't tested it yet.
There is still no sound, do not adjust your set .
Whats left that's planned for 1.0 (non beta):
- add sound track to auto-gray sequence
- add sound track to lip-sync pattern and test. If I have any trouble syncing the audio, I'll remove the pattern, but I'm not expecting that to happen.
- finalize menus, remove or not the freq. patterns.
- add a 30-80, and possibly a 20-80 "rocking" gray window pattern sequence
Finally, add my edits to Claus's very well done "manual" and hopefully persuade Claus to edit it and help make it look as good as before I "worked on it" . A couple iterations between us and that will be done.
Thanks for everyone's support and patience. Sorry it's taking much longer than originally expected.
Let me know if anyone sees any new issues on Beta 4.3.
Best, Scott
post #377 of 2211
The 4.3 upload failed last night, it is there now.
post #378 of 2211
Claus,
Thanks for the update and the effort. If you understand all this, it probably is easy but the effort involved in building a theater , choosing the right equipment, with value received in mind, and actually getting hooked up and set up, is mind boggling to say the least! Building my Dyna kits 42 years ago was a no brainer by comparison.
post #379 of 2211
Awesome...thanks so much for doing that.
Please take a gold star out of petty cash...
post #380 of 2211
Scott, I got 4.3 and tried it. It all seems to work as advertised. The frequency burst patterns now look right, too (sharp, clean and all the lines are visible). The re-encoding did it's job.
My WinDVD, Ver. 5, (on my laptop) reacted to the 4:3/16:9 flags correctly. I'm happy to do the final Instruction clean up once the calibration details get finished.
Sailor Bill -- I built my Dyna Kits (they had excellent instructions) about 42 years (+/- a couple) ago, too. A friend of mine is still using the stereo amp, the tuner and pre-amp are in storage (along with a pair of Heathkit Willamson Mono amps - using 6L6's & humongous transformers - along with my first University 312 corner loaded speaker).
post #381 of 2211
It all looks good, including the test patterns. Please don't remove anything.
Vern
post #382 of 2211
OK, but what can the freq patterns be used for?
post #383 of 2211
How about adjusting focus?
post #384 of 2211
Hmmm, I'll try it but I think that might be the last pattern I'd use for that. It being kinda fuzzy by design to begin with.
post #385 of 2211
Ever since this question first came up, I've been thinking about their usefulness.
In the past, frequency bursts were used, on CRT sets, to check the frequency response of the video chain and the display - horizontal resolution. However, since most of our displays, sources, cables, etc., should be good for at least 8MHz square waves (200 MHz bandwidth), these patterns (6.75 MHz max.) should not be that useful.
It doesn't hurt to leave them in, Vern Likes them . They are in the same category as the Belle-Nuit pattern (Vertical Resolution) and are so placed (a Horizontal Resolution test). I think I'll add that statement in the instructions (if Scott agrees to leave them in). The re-encoding that Scott did for Beta 4.3 fixed the blurriness problem.
post #386 of 2211
Freq sweeps are great for setting peaking/sharpness controls.
post #387 of 2211
You're right on that one, but doesn't that really require a scope (to do it properly)? Also, it's handier for CRT sets, not DLP/LCD PJs, isn't it?
I would think that sharpness can be set easier with the Zone plate tests on DVE & AVIA, although the bursts can certainly be used for that (the images should be sharp and clear with no blurring due to ringing. Peaking is more of a CRT adjustment, from what little I know about it.
post #388 of 2211
If we can find one thing that they can be used to adjust, I'll leave them. If we can't find anything, I don't know. The theme of the disc is "only what's needed to calibrate" (without a scope), bare bones simple. If the freq patterns are helpful for sharpeness then that's good for me. I'll try to confirm, but if anyone else can, that would be great. Thanks for pointing out that possibility Chris.
post #389 of 2211
I've been watching this thread for a little bit now and was wandering if just for s!!% and giggles if you could throw in a couple of old school eggs hidden in the menus on the dvd. I know that it would add little value to the intent of the dvd itself but it would be nice/cool to see say a Haley Barry picture from the movie Swordfish... you know wich one or maybe the famous Darla from finding nemo... or if your so inclined a picture of your mug . Whatever your heart desires ... a favorite song?
All kidding aside Im really looking forward to tring your finished labor of love. Wish i could have contributed to the efforts, but alas I live in the dark ages yet still , and do not have a dvd burner nor a dvd player that is capable of playing burned dvds other than retail. (toshiba 2008 first gen.) I do however feel that christmas will be very good to me this year so will see.
note ..... If it hasn't been said enough already I will say it again -- thank you for yours and the contributors efforts. I give you 5 gold stars,, one turkey dinner, two turtle doves and and and well you get the point.
Merry Christmas!!!
Btw .... if you have a fedex person deliver to your house and they look like might be on the verge of a nervous breakdown for god's sake give the poor soul a cookie .... it just might be me
post #390 of 2211
Well, here you go then.
They are very useful for revealing improper deinterlacing and scaling, which can degrade image quality. These are two things I would always check for before calibrating a projector. In my mind, calibration means more than just setting the 4 basic levels, gamma, and grey scale, it also means checking the end to end system for any issues that will compromise the image quality and correcting them.
Vern
