Hi all,
If you happen to have a digital camera and you can set its colour temperature like on Canon (and most other SLR type) digital cameras; then you have a tool which you can use to roughly calibrate your plasma (or other type) screen.
Essentially you set your camera white (colour temp) to 6500K (or other temperature for that matter if you find 6500 too yellow).
You then take a picture of your screen when it has a completely white screen. If the picture comes out with a bluish white then your plasma's white point (colour temp) is too high. If it comes out reddish or yellowish then the plasmas colour temp setting is too low. The amount of blue or yellow bias will give you an idea of how far away you are.
If it is in the ballpark the white should reproduce very close to a true white. This is crude in comparison to the next step which refines things much more.
If you own Photoshop CS2 as well as a (SLR) digital camera which can shoot in RAW mode (most do) you can do even better! Photoshop is able to open raw picture files in a utility called "Camera Raw". With this utility you can actually click on the white on the plasma screen in the picture you took and it will measure the colour temp of the white in question and give you a figure to work with.
If you don't have RAW mode on your camera you can still use the EYEDROPPER tool in Photoshop to help you get the right adjustments real quick. Simply use the dropper tool to analyse the white screen area of the JPEG picture you have just taken. You can examine the R,G,B values of the white area in question. Try several areas in the screen image and note the R,G,B levels that Photoshop shows you. When you calibrate the plasma you simply need to adjust the R,G,B levels relative to your findings with the eyedropper tool. Aim to make the R,G,B levels that are read by the eyedropper tool equal in the white area.
Eg, If the eyedropper tool in Photoshop shows your white screen area to have R: 230 G: 220 B:200. Then it means you'll have to increase the green and blue on your plasma settings.
Take another photo with the new adjusted settings on the plasma and examine the result with the eyedropper tool and adjust accordingly.
SO there you are. You can do your own calibration at home without anything more than your digital camera and Photoshop!
As far as I know this is the first time this has been described to calibrate a plasma or other AV display (for which it would work too).
Hope that gives others some ideas to extend this. Any questions welcome.
Ben
It's not a substitute for a colorimeter; but the cameras white balance should be very close to the mark. I've confirmed this with my EOS 20D and its 6500K setting. My monitor is calibrated but the technique does not require a calibrated monitor as the eyedropper tool will analyse the jpeg file independent of how it appears on your monitor.
Ben
