AVS › AVS Forum › Gaming & Content Streaming › Digital Recorders (PVRs) General › DMR-E85H can't set up
post #1 of 2
Bought a DMR-E85H at Future Shop. It was a demo. I got it for a song(that's probably why it won't work).
Any way hooked it up to my HK and my motorola cbt. Everything works, except I can't access the Guide menu to set it up. I just get a Black screen.
Everything is hooked up correctly. Still black screen when I try to enter the TvGuide.
Any thoughts?
thks :D
post #2 of 2
Try using a splitter, and send a cable directly to the unit, instead of from the cable box. That will get you analog ch listings.
And this isn't a digital box is it? If it is, you're going to run into a wall-these things don't work well-if at all, with digi boxes...
And the recorder must stay off for a full 24 hours-sometimes a little longer to download guide info. No turning on to peek, no scheduled timer recordings during this period..
This thread is locked
