AVS › AVS Forum › HDTV › HDTV Technical › y/pb/pr Component outputs from pc
post #1 of 5
It has been reported in other posts that at least two Cards will be on display at COMDEX. A number of AVS Forum members are Beta testing these Cards right now. Expect mass production from at least one of them before Christmas.
Ray Newstead
post #2 of 5
Ray,
From reading other posts in HTPC forum, I understand the card being discussed is an HDTV card that receives broadcast HDTV programming. I believe what fmjed is asking about is regular PC video card that has component outputs instead of the standard VGA connector that would eliminate the need for and external transcoder. Does your company have such a card? BTW which company do you represent? Thanks.
Jay
post #3 of 5
Anyone know if there is or will be a video card made for a pc that would output hd component video in the y/pb/pr format that would work with my panasonic pt56-wxf95.
post #4 of 5
Hang in there a bit longer. The is a new HDTV card about to be introduced that will have RGB and Y-Pr-Pb Output to an RPTV like yours.
Ray Newstead
post #5 of 5
Any word on who the manufacturer would be?
  Back to Forum: HDTV Technical
This thread is locked
