Originally Posted by sl@cker
Rib(and whoever else): do you use the settings listed here for your TV?:
http://www.avsforum.com/avs-vb/showt...&&#post7446179
Also, most tweak threads seem to say put sharpness at around 25-35. I find this makes way too many sharp, un natural edges on the picture. anyone else notice this?
I had my set calibrated. The key to getting rid of the unnatural edge enhancement is to do the following. Use Pro mode. Use Warm setting. Turn off DTE and Detail Enhancer. Turn the DRC settings way down to like (9,9) or less. Set sharpness to 25.
Sharpness at 25 is what the ISF tech measured to be correct for hi-def material with the aforementioned settings. Sharpness at 15 is what the ISF tech measured to be correct for 480p.
Hope this helps.
