Originally Posted by Rhett_in_SoCal
I have the 60" SXRD XBR1, and have just noticed a yellow line down the right side of the screen on bright content. It aligns pretty closely/almost perfectly with the width of the 4:3 pillarbox line, so I'm wondering if watching pillarboxed content is making one of the panels fail. (I hate stretching SD content so I watch it pillarboxed.)
Has anybody else had this happen to their SXRD? The set is 13 months old, so I'm glad I have the extended warranty.
The line is most noticeable when I go to MemoryStick mode as it has a grey background. I first noticed it when firing up the Xbox360. You can't see it on dark content, but when the screen is white or light grey, it's in your face.
Yes, my set recently started showing the exact same thing in the same place as you described. It tends to lessen the longer the set is on (hours). Sometimes it's not there but then most times has a very slight green tinge in the upper right corner...then, two days out of seven, nothing abnormal !
Apparently the OB will need replacing, but I am going to wait awhile for that, I do have the EW, like most of us do in this and the owners forum.
I purchased this set back in late NOV. 2005 ( NOV. build date)
