AVS › AVS Forum › Display Devices › Rear Projection Units › Owners Tweaks & Settings Sony KDSR-50/60XBR1
Owners Tweaks & Settings Sony KDSR-50/60XBR1 - Page 50
post #1471 of 1644
Originally Posted by PKingRoch View Post
What post has the settings on it for the new OB?
The post was made on 1/29/07 by brenthenry. It's on the previous page, I believe. My fingers are crossed that the new OB will have greater longevity than the previous one. I don't know what these things cost, not to mention installation, if it goes south after the warranty expires. I suspect it is not cheap.
post #1472 of 1644
I read somewhere on this forum that Sony has extented their warranty for a replacement OB until the end of 2008.
post #1473 of 1644
Its been posted already but to save you some time
http://esupport.sony.com/US/perl/new...R1&news_id=185
post #1474 of 1644
Got it Thanks!
post #1475 of 1644
Sears recently replaced my OB and lamp under my EW (no current cost to me). They gave me an invoice that showed it would have cost $2300 without the EW. That's inflated because they don't show the $750 they get back for the core and they charged $350 for the lamp.
post #1476 of 1644
You may want to cross more than just your fingers. Some people, myself included, are noticing problems right away with their 'new' OB's. Some are willing to live with their slightly flawed picture for now. I dont think we should let Sony off the hook that easily. IMO, if your picture does not look like it did when you brought the set home, call Sony back and have them make it right. Otherwise Sony will believe the new parts they have shipping out to the defective ones are actually good.
post #1477 of 1644
I'm new to these forums... and read through several pages of posts, but It still isn't clear to me what could be wrong with my TV (KDSR60XBR1). The first thing that I had notice was that when watching a 4:3 signal when I would switch to any widescreen format there would be a yellow line that started near the bottom right and moved (getting slimmer toward the top)... eventually I notice a more dramatic yellowing in the upper center of the screen area that has now pretty much encompassed the entire screen. I've fiddled with all of the settings (in Pro mode) but can't get the yellow to go away. I was going to try replacing the bulb, but all of the discussion about the optical block replacement makes me think that could be the problem. Any opinions if I'm in the "need a new OB club?"
post #1478 of 1644
The yellowing you describe (not the line) would appear to be the optical block. Fortunately (you may already know this), sony has offered to repair optical blocks (labor and parts) until october '08 for the XBR1 owners, regardless of purchase date. I'd get sony going on replacing it.
post #1479 of 1644
how does one access the service menus? to get to the settings
post #1480 of 1644
I started this thread a long time ago and had one of the first 60" XBR1 sets shipped to the US. The funny things is that my set is rock solid with a beautiful picture and I can't detect any discoloring in B/W, from the memory stick screen , etc. I do have a little green on startup but then it quickly goes away. I'm wondering if there was a large batch of bad OB installed or if there is another issues that would only effect certain sets. I'm also woriied that it may show up one day.
post #1481 of 1644
How many hours do you have on your set? I had around 5,000 hours on my lamp before I noticed the "blob". It got progressively worse and I got a new OB at 7,200 hours.
Unless you use your set more than most, you don't have 5,000 hours.
post #1482 of 1644
I got my set on 10-08-05. I watch about 6 hours a day of TV. Yeah I know - I was told I'd go blind from other negative activities too but.... So that would be around 3000 hours of bulb usage. I hope you're wrong about my set developig problems. Did they try replacing the bulb before doing the OB install? What in the OB would degrade from usage? Did the tech say? Also, do you ever turn off your set (:
post #1483 of 1644
I got my set on 10-08-05. I watch about 6 hours a day of TV. Yeah I know - I was told I'd go blind from other negative activities too but.... So that would be around 3000 hours of bulb usage. I hope you're wrong about my set developig problems. Did they try replacing the bulb before doing the OB install? What in the OB would degrade from usage? Did the tech say? Also, do you have turn off your set (:
I changed bulbs the same time as the OB. We're retired and the set is turned on around 10 in the morning and off around midnight. It normally just runs in the background on a news channel during the day. If we walk through the family room and something catches our attention, we stop and watch it.
post #1484 of 1644
Has anyone talked to a tech that could explain what fails on these OB's?
post #1485 of 1644
I have to 50xbr1 and am looking for some user friendly adjustments/tweaks I could make to get the most out of this TV, I did some minor tweaks but Iam by no means electronic savy and have read a couple extremely advanced tweaks for this and dont want to mess with all that if possible. I prefer viewing this tv in vivid/cooler colors over the warm and would like to tweak the clarity/sharpness if possible. Again please remeber Iam a newbie. Thanks
post #1486 of 1644
bump...
post #1487 of 1644
Got my 60" SXRD back a couple of days ago... Hillems Coast TV came and picked up the TV last Thursday... performed the repair and returned it on Tuesday. TV looks like it used to when it was brand new. Hopefully it will stay that way. Has anyone been keeping track of the number of times the blob has returned? Any ideas on longevity of repair satisfaction?
post #1488 of 1644
If you read the owner's thread, you will see many instances of where the blobs have returned.
Normally, Sony has been replacing the sets after one or two replacements have "gone bad".
post #1489 of 1644
Wow so is there a cliff's notes on this thread!?!?!?!? I don't want to have to read through all 50 pages!!!
post #1490 of 1644
These are the cliff notes.
post #1491 of 1644
Quick question...
To calibrate your tv can i just go by some of the recommended settings posted on here. Or... do i have to wait and first buy a DVD, like AVIA, and then do everything?
post #1492 of 1644
Quick question...
Proper calibration must be unique to a specific set. Using the "settings" from another set may make you picture better; or they may make it worse. If you could use one set of numbers on all sets to obtain the optimal picture; don't you think that the factory would use those numbers?
Bottom line: Your set must be individually calibrated if you want to be sure of an improved picture. How good, depends upon the tools and skills of the calibrator. Least improvement is "Joe Sixpack" looking at the picture and adjusting user controls. Next in line is Joe Sixpack using Avia or DVE. Next improvement is doing some reading/studying and then using AVia/DVE. Next improvement is probably using DIY techniques/equipment (e.g., Spyder TV Pro) discussed on the calibration forum. Best possible picture requires one of the skilled professional doing the full ISF process.
post #1493 of 1644
Agreed.
Lighting in your room, position of the set relevant to the walls and ceiling, color of the walls and ceiling and flooring, all have an impact. That, plus the OBs tend to all be a little sensitive, I doubt any two are 100% alike.
Well worth the price of the pro calibration IMHO.
-gil
post #1494 of 1644
Well after 2 OB replacements, and a second replacement set gone green Sony has just upgraded my membership to the XBR2 Club BABY!!. So I just want to so goodbye to this depressing green tinged forum. I have just added 60 more watts to my bulb and FULL 1080P to my Sony PS3. Oh and bye the way for everyone who is living in this illusion that you cant tell the difference between 1080p and 1080I to make yourselves feel better about your green xbr1 purchase your wrong. Next time don't ask stevie wonder for High definition advice. So long and hopefully see all of you in the xbr2 Forum.
post #1495 of 1644
I know what you are feeling. I too switched from a 50XBR1 to a 60XBR2. I did so after only 1 OB switch, though. This has to be the most depressing forum due to all the green-blob issues. People are chumps if they feel satisfied with the XBR1. So long suckers, come visit in the XBR2 forum. He He.
post #1496 of 1644
Real class act! I'm sure that the XBR2 thread will be thrilled with your valuable input.
post #1497 of 1644
haha i like your thinking...
BTW i just ordered the DVE disc today. Do you have any suggested reading/studying for that???
post #1498 of 1644
A couple years ago, I downloaded (from source currently unknown) a 20-30 page set of instructions for DVE.
Did a quick "google" today for "DVE Instructions" and there are many sources. One below has good but brief instructions for the basic calibration.
http://www.ramelectronics.net/html/V...libration.html
Suggest you also check more of the google sources. I would also go to the AVS calibration forum and do a search for DVE instructions.
Good luck.
post #1499 of 1644
Okay, so my SXRD 50" OB went kaflooey (yellow tinge, everyone looking jaundiced), and I got Sony to send over a warranty replacement with an installer.
Now it's up and running with a new OB, and all my Greens are Blue - grass, most noticeably, on MLB, Football, and nature programming.
I've re-instated my previous ISF caliration settings, no good. I've tried every setting on this thread, no change.
Now what? I dropped $3500 on this TV in October 2005, and everything was great until the yellow tinge of death last month. I thought the OB replacement would "cure all ills", but no.
WTF? Now what?
-gil
post #1500 of 1644
From what I can tell after playing with settings all night is that my greens are blue and my blues are green. Any ideas?
Video 7, HDMI input from SA 8300HD STB/CableVision New Jersey. ISF calibrated settings from before the OB was replaced, as follows (those not listed are at Sony defaults for Video 7):
Pro mode, temperature Neutral, power saving off.
Picture 48
Brightness 27
Color 27
Hue R1
Sharpness 28
White Balance (I have only listed the ones that changed):
B-Gain -17
R-Bias +2
B-Bias +1
-g
  Back to Forum: Rear Projection Units
