Originally Posted by
kk85
Hey, I hate to be lazy, but there's a lot of posts in here... I thought I'd ask if someone could please link me to the generally accepted settings in this thread, if such a post exists? :P (This is assuming ideas have changed since the post on the first page, since it was made over two years ago. If not, I'll just use that one then.
Thanks in advance for any help!
Here's one 50" owner's settings I copied (almost) a couple of years ago, but remember, every set is different and YMMV! Also, many say the preferred method is to just get a view of something you can recognize/compare to actual (like the skin on the back of your hand) and tweak the settings to give a realistic result.
"Picture Mode: Pro, Iris: 3, Picture: 58, Brightness: 31, Color 30, Hue:0, Sharpness: 25, Color Temp: Warm, Noise Reduction: Low ,Direct Mode: Off, DRC: Cinemotion, DRC: Custom 3 default settings, Advanced Iris: Low, Color Corrector: High (i change this to high myself to enhance bright colors without affecting skin tones), DTE: Low, Clear White: Off,
Detail Enhancer: Medium, Black Corrector: Low, Gamma Corrector: Low,
R-Gain: -13, G-Gain: -6, B-Gain: 0, R-Bias: 3, G-Bias: -3, B-Bias: -3"
