AVS › AVS Forum › HDTV › HDTV Programming › Verizon FiOS HDTV
Verizon FiOS HDTV - Page 551
post #16501 of 17987
Originally Posted by jeepmatt View Post
Ken-
I haven't actually seen the Cisco's in person - but heard from a few friends' that got them. Based on their feedback pretty solid - I also heard they were a LOT more cost friendly than the Moto's from VZ's standpoint.
My daughter has a Cisco, I have a 7332.... as far as I can tell, there is no real difference. I think the Cisco is a tad more responsive, but that's only because I am picky
post #16502 of 17987
Originally Posted by rich3fan View Post
DNW, I think there is a list of "compatable" eSATA drives somewhere on the myVerizon website. A good place to start anyway.
I tried a couple of external hard drives. The first one worked for a couple of days, then stopped working. I substituted a different drive, which was not recognized at all. I just got off the phone with Verizon. They told me I could upgrade to the 7232 (I think that's the model number) with about 50 hours of internal storage, for $39.95. That's a one time charge, no increase in monthly costs. However, if I ordered a replacement because of a mechanical issue with my current unit, there would be no charge, but I might get the same model number or the newer model. I went with the no cost swap-out. My new DVR has been sent overnight mail, so I might have it as early as tomorrow.
Interestingly, the representative told me that she has not heard of anyone using eSata with the 25 hour model, even though it does take an external drive. She said that when people are using eSata, they almost always have the 50 hour model.
I will report back when it arrives and I hook it up.
BTW, when eSata stopped working, I lost all previously recorded shows, even the ones recorded on the internal drive. They are listed, but won't play.
post #16503 of 17987
Ken-
Not Verizon specific, but the costs of comparable boxes between cisco and motorola are very close. Verizon may have brought in a cisco to keep moto from having a monopoly on their network and keep costs in control although having dual conditional access systems is a nightmare.
post #16504 of 17987
I have the Moto 7232 model and am using a Cavalry enclosure with 2TB drive. I installed it sometime around Thanksgiving. It recorded a show and then at some point, either the HDD or the set-top lost it's mind and the drive was no longer showing up. When I finally got around to adding it again, when I selected "Enable more storage" so I could go through the process again, it told me the drive was already enabled and I just needed to reboot the set-top box so it could see drive. Did that and it still wasn't there. Did it again. Still not there. Cycled power to the hdd and then did it one last time and the set-top finally saw the hdd again and my recording was still on it. I did not, however, check the recording so it could very well be the same for me, that it is listed but won't play. That wsa 3 days ago now, I will check it sometime over the weekend to ensure it is still being seen by the stb and recording shows to it.
post #16505 of 17987
Does anyone else think that the STB HDD should be filled up before the external HDD is used or am I the only one? Seems odd to me the way they implemented it.
post #16506 of 17987
Jakes-
I was part of the beta team that got 1.9 back in December of 2010. Funny you said that. Alot of us thought the same thing at the beginning - but the thought was to write to the external drive 1st, to allow the main DVR to keep it's storage at a minimum if possible - in order to handle basic features such as buffering, etc...
To me, at least, it made more sense after the engineers gave us their explanation.
post #16507 of 17987
Oh I get it, they would rather have the wear and tear on our gear before their own gear. Makes perfect sense to me too from a Verizon perspective!
post #16508 of 17987
If you were so inclined, you could fill an external drive, put it on the shelf, and connect another drive. Repeat until you run out of shelf space.
A drive can be reconnected to the same DVR at any time and the shows on it will be intact.
post #16509 of 17987
Jakes-
My very noisy first external hard drive would attest that they do NOT do buffering on the internal. I actually did some experimentation around that.
Upon a fresh boot, the STB would use the internal for the buffers. However, once you started recording anything, the buffers would shift to the external. You can see evidence of this as well when you eject the drive, the live buffers get cleared out.
It would make sense to put the live buffers on the internal and I would certainly prefer that they did that, but that's not the way it's working currently.
post #16510 of 17987
Ken-
Interesting. I'm surprised then that VZ doesn't phase out the Mot boxes over time...unless it's too onerous a task.
post #16511 of 17987
I'm cross-posting this from a thread I started in the HDTV Technical sub-forum. I figured someone in this thread might have an answer for me.
Prior to the two Cisco STBs I have now (both are 335HDC units), I used to have Motorola STBs and on those you could hit Power -> Select -> Select (with the STB already powered on) and be able to access a "hidden" diagnostic menu.
This sequence of keys (tried on both the STB itself and the remote) does not work for the Cisco boxes. I'm experiencing some stuttering with HD VOD content and was really hoping to take a look at the diagnostics to see if I could glean any info which might help me solve the problem.
Anyone know what key sequence is necessary to access this menu on the Cisco STBs?
post #16512 of 17987
A question on something I should already know, but don't!
If I have 3 or more shows I want to record at the same start time, I can look at the schedule, find them, pick the ones that will be rebroadcast later during the week (USA Network, TNT, etc.), choose a later start time amd I'm good.
How do I set up the DVR to record the same show at the later start time every week? I can't seem to get it to do this. The weekly feature always defaults to the first showing.....
nw
post #16513 of 17987
nw
Doesn't it have a priority order for recording like TiVo does? With those you would give shows that are repeated multiple times a lower priority for recording than one that is only shown once. It's worked great for the 10+ years I've been using TiVos.
post #16514 of 17987
nw
Make sure you are set to record all episodes in any time slot (not first run only). Then set priorities for the shows. This is all in the DVR menu (the menu one level above where the recordings are).
post #16515 of 17987
Verizon and Redbox forming a joint venture.
http://www.prnewswire.com/news-relea...138772929.html
post #16516 of 17987
I'll try this, but I think I did this while back and ended up with a HD full of White Collar reruns during a marathon weekend. or multiple of the same episode....can recall.
Will it only record the next run of the new episode?
thanks,
nw
post #16517 of 17987
thanks,
nw
You can select a specific channel in the options, and I think you can choose a specific time, too.
Doug
post #16518 of 17987
Doug
I record a number of shows including white collar specifically in the middle of the night.
post #16519 of 17987
Exploring free VOD options after a new FIOS install and discovered numerous options like this, including a Japanese garden, stills of Dutch paintings, and more, with most (~55 mins) set to electronic 'mood' music, although the Dutch stills, I think, used Chopin piano pieces. The VOD program options, in general, seemed endless, with submenus upon submenus. -- John
post #16520 of 17987
I had a homemade eSATA 2TB drive in a SATA housing and it was skipping and louder than a jet-plane. I bought a refurb 2TB Phantom Greendrive off Amazon and it's nice and quiet and seems to be glitch free (at least for now). Worth the extra money just for the silence.
post #16521 of 17987
Anyone having a bad FIOS TV outage in the DC/MD area?
post #16522 of 17987
Some problems here
post #16523 of 17987
What channels? No issues that I know of here.
post #16524 of 17987
Ok now for me.took several minutes to change from 504 to 526.
post #16525 of 17987
I haven't had any outages, but I for several weeks I've been experiencing pixelation, macro blocking and general breakup in just every show for a few seconds. I have many recorded and just about all of them show it, though never for very long. My internet connection is great at 35/35 but the compression or other issues in the TV signal are not good.
post #16526 of 17987
Yes that too.
post #16527 of 17987
Originally Posted by jmschnur View Post
Yes that too.
In Richmond too.
post #16528 of 17987
In Richmond too.
I'm in Richmond and haven't seen any problems. To be more specific, served by the central office at 34th & Hull St.
post #16529 of 17987
Delco pa, I get tons of macro and pixelating. I also get it going into nearly every commercial break, which seems odd.
post #16530 of 17987
Is there anyone that can use the PDA app for remote control that does NOT have FiOS as their ISP?
  Back to Forum: HDTV Programming
