Originally Posted by
DaveFi
Which ones? Because there are quite a few available on Netflix. Frankly I'm not even sure why you'd want to bother with the lo-res SD mess that's on FIOS.
I look at some of it on the channel first, then if I like it I can go to Netflix, Amazon etc.
The series B Gata H Kei, wasn't on Netflix as well as the second movie from Eden of the East. They showed both on the Funimation channel but I ended up purchasing B Gata H Kei from Amazon HD downloads and Eden of the East: Paradise Lost in HD from Xbox LiVe Zune.
But I also see they have a monthly plan where you pay $8 each month and get HD access to all the shows. Which I probably would have used instead if I had known about it since it would have been cheaper(B Gata H Kei cost me $21 for seven episodes(I actually watched the first five in SD
on FiOS) and the Eden of the East movie cost me around 1000 MS points). I would have just needed to connect my Netbook or Laptop to an HDMI port on my DVDO DUO. But I stopped using an HTPC many years ago so that is really not the preferred method for me to watch content.
