AVS › AVS Forum › Video Components › Home Theater Computers › PlayList_Manager & Record_This
PlayList_Manager & Record_This - Page 52
post #1531 of 2785
Originally Posted by AllenDB
I knew it. I looked into the documentation for the PLM and it says an option record must begin with ">> ". Note the space after the ">>". Like I said the PLM is not as flexible in the formatting of option entries. Sorry. Put a space after the ">>" and all should be well.
Thanks for the catch...the options are now not being recongized as folders, but I am still having issues getting it to go into the correct subfolders...If I specify the subfolder it finds the files in it, but if I specifiy the file above it, it doesn't....I have attached my ini, and a snip of the search...
Code:
01/01/07 06:08:51 Get_All_TP_Files: Scanning for extension ts
01/01/07 06:08:51 Check_All_Folders:   0 Folder G:\\Fusion\\Capture
01/01/07 06:08:51 Check_All_Folders:   1 Folder G:\\overflow
01/01/07 06:08:51 Check_All_Folders:   2 Folder G:\\Keep\\Movies
01/01/07 06:08:51 Find_Files_In_All_Folders: 10/28/2005 15:07:43 Dylan--Long Way home
01/01/07 06:08:51 Check_All_Folders:   3 Folder E:\\BTV
01/01/07 06:08:51 Check_All_Folders:   4 Folder E:\\overflow
01/01/07 06:08:51 Check_All_Folders:   5 Folder E:\\keep
01/01/07 06:08:51 Check_All_Folders:   6 Folder F:\\myHD\\capture
01/01/07 06:08:51 Find_Files_In_All_Folders: 12/13/2006  9:39:31 The Unit - Silver Star
01/01/07 06:08:51 Check_All_Folders:   7 Folder F:\\H2
01/01/07 06:08:51 Check_All_Folders:   8 Folder F:\\BTV watch
01/01/07 06:08:51 Check_All_Folders:   9 Folder I:\\keep \t
01/01/07 06:08:51 Get_All_TP_Files: Scanning for extension tp
01/01/07 06:08:51 Find_Files_In_All_Folders: 12/19/2006 21:01:40 Big Day - Stolen Vows
01/01/07 06:08:51 Find_Files_In_All_Folders: 12/19/2006 20:31:41 Big Day - The Bachelor Party
01/01/07 06:08:51 Find_Files_In_All_Folders: 12/16/2006 21:01:41 Flip This House - Alder Lane
01/01/07 06:08:51 Find_Files_In_All_Folders: 12/28/2006 21:01:41 Sweet Home Alabama [12-28-06]
01/01/07 06:08:51 Find_Files_In_All_Folders: 12/23/2006 21:01:40 The Unit - Unannounced [12-23-06]
MYHD_Params.ini.txt 1.4755859375k . file
post #1532 of 2785
Additional debug info. KaXKID, I might need some input here. Let me see first.
RF, can you install this RT, run again and post the log?
Record_This.zip 241.2890625k . file
post #1533 of 2785
Here you go.
Ronnie
Record_This_Log.zip 2.0048828125k . file
post #1534 of 2785
Originally Posted by AllenDB View Post
I printed out the particulars and compared what the XML showed and what RT scheduled. For WSMVDT it correctly (it appears) set vir to 232, phy to 10, sub to 1, and pn to 4.
WNABDT vir to 235, phy to 23, sub to 1, and pn to 6. I don't have a clue as to why the Fusion console shows D-1093 and D-1085. I'll poke around some more.
Hold on, I'm going to post an RT with additional debug data. Maybe the last fix for another new user is causing a problem here.
the problem is that these channel names are for the ota channels, not the cable channels. the cable channel names are not the ones with DT, but probably SD or HD. RT is not supposed to be scheduling the ota physical channels. WNABDT should be on D850 not phych 23. phych 23 is ota, right?
so, we, probably, need to change the definition to:
>> mapfusionname D850 WNAB
not:
>> MapFusionName D850 WNABDT
post #1535 of 2785
not:
When I used:
It schedules the shows on the station listed in the XML file, ie- D235 for WNAB. I think D235 is the channel that gets programmed into the set top boxes from my Cable Company (if you use a set top box.)
WNAB OTA (The WB in my area) is on air channel 23, Virtual Channel 58 Sub Channel 1
rf
post #1536 of 2785
Originally Posted by Ronnie Ferrell View Post
When I used:
rf
ok, D235 is not in the xml file. 235 would be in the xml file, no D. the xml file, normally cantains a number of "names" for the same station. the ones with DT suffix are normally the designation in the zap2it data for the ota stations.
in the mapfusionname definition, we want to use the name that zap2it uses for the cable HD channel for WB. we want to stay away from the name that zap2it uses for the ota station. without the psip data from your cableco, the mapfusionname definition is the way for RT to match up the fusion virtual number of 850 to the zap2it program data for WB, so what is that name in the zap2it(xml) data?
btw, the info we need would be the name of the channel you checked in the digital cable listing of the zap2it list of channels when you signed up for zap2it.
post #1537 of 2785
Here you go.
Ronnie
I would stop using that debug version I posted. For some unknown reason it causes DB access failures. Or maybe that is because of the changes in your tables. In any case it is not displaying what I wanted to see.
post #1538 of 2785
i've seen those errors when the data is already entered into the database. i guess the fusion app won't allow a second instance of the same data with only one tuner.
post #1539 of 2785
Here is a snip from my zap2it config file which is set for digital cable lineup in zip 37204:
timezone: -0600
lineup: TN41505:X
channel: 231 WKRNDT
channel: 233 WTVFDT
channel: 235 WNABDT
channel: 236 WUXPDT
channel: 234 WZTVDT
channel: 232 WSMVDT
channel: 206 INHD
channel: 240 WNPTDT
channel: 241 WNPTDT2
Here is a snip from the xml file:
231 WKRNDT
231 WKRNDT TN41505:X
231
27 WKRNDT fcc
WKRNDT
WKRNDT (WKRN-DT)
ABC Affiliate
233 WTVFDT
233 WTVFDT TN41505:X
233
56 WTVFDT fcc
WTVFDT
WTVFDT (WTVF-DT)
CBS Affiliate
235 WNABDT
235 WNABDT TN41505:X
235
23 WNABDT fcc
WNABDT
WNABDT (WNAB-DT)
CW Affiliate
234 WZTVDT
234 WZTVDT TN41505:X
234
15 WZTVDT fcc
WZTVDT
WZTVDT (WZTV-DT)
Fox Affiliate
232 WSMVDT
232 WSMVDT TN41505:X
232
10 WSMVDT fcc
WSMVDT
WSMVDT (WSMV-DT)
NBC Affiliate
206 INHD
206 INHD TN41505:X
206
INHD
iN Demand High Definition
Satellite
240 WNPTDT
240 WNPTDT TN41505:X
240
46 WNPTDT fcc
WNPTDT
WNPTDT (WNPT-DT)
PBS Affiliate
241 WNPTDT2
241 WNPTDT2 TN41505:X
241
46 WNPTDT2 fcc
WNPTDT2
WNPTDT2 (WNPT-DT2)
PBS Affiliate
Hope this helps.
rf
ps- Again, the one station in my area which is > 100 works with MapFusionName:
Dump_All_Sub_Channels: Cable channel 115 Sub_Channel count 1 Str Length 122
Dump_Sub_Channel: Name D1150 Virtual Channel 1150 Sub Channel 1 Program Number 1
When I:
>> MapFusionName D1150 WNPTDT
It will schedule a correct show on D-1150.
The issue is with stations < 100.
(not sure if that bit of info helps or not...)
post #1540 of 2785
timezone: -0600
lineup: TN41505:X
channel: 231 WKRNDT
channel: 233 WTVFDT
channel: 235 WNABDT
channel: 236 WUXPDT
channel: 234 WZTVDT
channel: 232 WSMVDT
channel: 206 INHD
channel: 240 WNPTDT
231 WKRNDT
231
27 WKRNDT fcc
WKRNDT
WKRNDT (WKRN-DT)
ABC Affiliate
233 WTVFDT
233
56 WTVFDT fcc
WTVFDT
WTVFDT (WTVF-DT)
CBS Affiliate
235 WNABDT
235
23 WNABDT fcc
WNABDT
WNABDT (WNAB-DT)
CW Affiliate
234 WZTVDT
234
15 WZTVDT fcc
WZTVDT
WZTVDT (WZTV-DT)
Fox Affiliate
232 WSMVDT
232
10 WSMVDT fcc
WSMVDT
WSMVDT (WSMV-DT)
NBC Affiliate
206 INHD
206 INHD TN41505:X
206
INHD
Satellite
240 WNPTDT
240
46 WNPTDT fcc
WNPTDT
WNPTDT (WNPT-DT)
PBS Affiliate
241 WNPTDT2
241
46 WNPTDT2 fcc
WNPTDT2
WNPTDT2 (WNPT-DT2)
PBS Affiliate
Hope this helps.
rf
When I:
ok, tune to CW using the fusion app.
schedule a 5 minute recording using the fusion app.
post a copy of your epg2list.mdb
we'll get this yet!
post #1541 of 2785
we'll get this yet!
Here you go! The 5 min. recording on CW should be the only manual recording listed. All the others are recordings I've done with RECORD_THIS OTA.
rf
Epg2List.zip 28.1708984375k . file
post #1542 of 2785
rf
ok, you shouldn't need the mapfusionname option.
try the earlier RT version linked below using your original channel map:
>> channel WKRNDT 92 921 1 CABD
>> channel WSMVDT 93 930 1 CABD
>> channel WTVFDT 92 920 1 CABD
>> channel WNPTDT2 86 868 1 CABD
>> channel WZTVDT 93 931 1 CABD
>> channel WUXPDT 85 851 1 CABD
>> channel WNABDT 85 850 1 CABD
>> channel INHD 87 870 1 CABD
http://www.avsforum.com/avs-vb/showt...&&#post7720550
post the results, so we can go further, thanks.
post #1543 of 2785
I may have figured this out.
post #1544 of 2785
Success!
I'm attaching the log file as well. The older version of RECORD_THIS broke my file naming scheme and looks to have a conflict with my "newer" not_seen DB, but at least it works with this version!
rf
ps- Let me know if you need me to post any of my DB files or to run any test with updated version.
worked.zip 2.244140625k . file
post #1545 of 2785
More info:
I just noticed in my log file that a show on PBS (D1150) did not get scheduled, (Nova). I edited my ini file and added mapfusionname back for D1150 (the one channel that I have that is > 100) and removed the "Channel" command for it. This corrected the error of not scheduling the recording of Nova.
So with this older version of RECORD_THIS, it works, but I have to use CHANNEL for stations < 100 and mapfusionname for stations > 100.
rf
post #1546 of 2785
RF,
Keep that ancient RT that KAXKID referenced but could you try this next one?
I ask because I can't test QAM much less cable stuff.
post #1547 of 2785
RF,
Sure. Let me know how you want me to test it. Like what setting in my .ini file, i.e.- with mapfusionname or channel, etc.
rf
post #1548 of 2785
rf
Use the ini file just like you have it from yesterdays successful run. It this version doesn't run the next one d--n well will.
post #1549 of 2785
Using the record_this you just posted above with the ini file that works with the old version of record_this from KAXKID, I get a program crash with the "send error report to MS" popup box. If I run it with the ini file that tries to use mapfusionname instead of using channel, I get the same result as yesterday. D920 gets scheduled to D1092 and D850 get scheduled to D1085.
I'm attaching the ini file that works with the older version posted by KAXKID and that gives the crash with the version you just posted.
Do you need the logfile from the record_this "crash"?
rf
Record_This.zip 0.6552734375k . file
post #1550 of 2785
More info:
rf
yes, in the channel map i posted, i had removed the entry you had in your channel map for D1150 because it should not work with the "channel" option. D1150 should use the "mapfusionname" option. the rest of your stations are less than 100 and should use the "channel" option.
sorry about the other errors that showed up, but i had wanted to test the channel mapping from the earlier version. that version had the channel mapping working for your type stations.
the test using the earlier version shows that somewhere along the way with all the various upgrades and added features to RT, the channel mapping for your type stations has been corrupted.
post #1551 of 2785
I'm sure the bug got into the 12/5 version. Happened while fixing the other new user's problems. This RT had better fix it. RF would you mind?
And this PLM should check subfolders. And Sterno3 I ran and found files in subfolders. It even found my timeshifting files all hundreds of them. In fact I had to pull that folder out of the ini.
Sure is a problem with the servers the last few days.
myhd_playlistmgr.zip 60.9775390625k . file
post #1552 of 2785
ok, this RT version(compile date jan2, 2007 15:55:06) works for the fusion channel mapping for my cable analog and qam with(cable option) and without psip(mapfusionname option), all at or above rf100.
i used my ini with a lot of the added "features" enabled while testing the channel mapping and didn't get any errors.
i did not test ota or multiple fusion tuners or remote fusion.
post #1553 of 2785
I used it for OTA last night. The rerun season is finally over and it recorded new Law & Orders.
post #1554 of 2785
Allen - since I only have a MyHD card and don't have a Fusion card I have given up following this thread for the most part.
But I still care about Playlist manager. Is there still work going on updating this - as I see a new revision mentioned above but no discussion of changes.
Perhaps separate threads would be better when there are disparate programs involved
Thanks for your work so don't take this wrong.
post #1555 of 2785
Perhaps separate threads would be better when there are disparate programs involved Thanks for your work so don't take this wrong.
I s'pect that if you hold your breath for a bit your wish will indirectly come about. What I'm saying is that after the next release of CW-EPG I'll probably be the only user of RT and the discussion in this thread will migrate back to the PLM.
Checking back a few posts you'll see that Sterno3 asked for the PLM to check subfolders. I responded that that feature had been asked for before but I was too busy then working on RT. Now that RT is mostly stable, well it was , I had time to look at it again. And it should be working now with that last post.
So yes, I'm still working on the PLM. Right now its being modified to use the new Helper which is only used with networked machines.
post #1556 of 2785
I still get the "send error report to MS" crash with this verion (compile date jan2, 2007 15:55:06) when using the ini file that works with the older version of Record_This posted by KAXKID. Using MapFusionName with this version for all of my stations produces the same D1092 scheduled for D920 error as before for stations below 100.
rf
ps- the older KAXKID version worked last night and all 5 of my scheduled shows were recorded properly.
post #1557 of 2785
So even us "Fusion only" users will not be using RT??? (I have not read the CW-EPG thread because I thought it was for MyHD only...)
rf
post #1558 of 2785
I expect that there will be more than a few folks who'll stick with RT, since they've got it working already and it does what they need to do. But, yes, the next CW_EPG full version will indeed support both MyHD and FusionHDTV with an easy-to-learn GUI frontend, so there likely will be a number who'll switch, as Allen predicts.
post #1559 of 2785
rf
To say I'm getting pi__ed would be an understatement.
I've pm-ed you and would ask that, again, could you send me your operating ini and a log from the successful run with all approprioate options turned on?
I was sure I put it back the way it was. Actually I think I have the code from that May release. I'll look at that code and start thinking about a simulator to try and solve my screwup.
post #1560 of 2785
i know how to get the subtitle to appear in the log file and in the actual file name, but it is not getting included in the actual capture name as appears in the capture list in myhd or in myirc.
is there anyway to get this to show?
