AVS › AVS Forum › Video Components › Home Theater Computers › PlayList_Manager & Record_This
PlayList_Manager & Record_This - Page 9
post #241 of 2788
Originally Posted by jldet5 View Post
I've been all over the TV listings at ZAP2IT and can't figure out how to download the XML or program that creates it. I'm usually not this helpless but darn if I can find it!
xmltv is at http://sourceforge.net/projects/xmltv
Before you configure it go to labs.zap2it.com and sign up. (This is completely different from the regular sign-up for zap2it.)
post #242 of 2788
One thing that can be confusing is that Zap2It has there own Schema format for the XML output called XTVD. Record_This is using the XMLTV format and thus the XMLTV application.
post #243 of 2788
Thanks guys. Its all making sense now. For some reason I got the impression the code was at ZAP2IT. Signed up and got the latest code. Thanks!
post #244 of 2788
Okay, I can almost get it working. Tried to schedule Dr. Phil and Surface. Surface shows in IRC and in slot 1 of capture panel. An edit to Surface brings up Dr. Phil info. The Physical 0s also look like a problem?
01/22/06 22:00:11 Record_This: **********************************************************
01/22/06 22:00:11 Get_Next_Record: >> xmlfilename C:\\Documents and Settings\\JLDET5\\My Documents\\Jeff Downloads\\XMLTV\\myhdz.xml
01/22/06 22:00:11 Get_Next_Record: <<>> showxml
01/22/06 22:00:11 Get_Next_Record: <<>> scheduleconflicts
01/22/06 22:00:11 Get_Next_Record: >> filenamestyle chname_date_title
01/22/06 22:00:11 Get_Next_Record: >> directorystyle none
01/22/06 22:00:11 Get_Next_Record: >> showoldschedule
01/22/06 22:00:11 Get_Next_Record: >> showaddedschedule
01/22/06 22:00:11 Get_Next_Record: <<>> showallprograms
01/22/06 22:00:11 Get_Next_Record: <<>> today
01/22/06 22:00:11 Get_Next_Record: >> tomorrow
01/22/06 22:00:11 Get_Next_Record: >> showallchannels
01/22/06 22:00:11 Get_Next_Record: <<>> reruns off
01/22/06 22:00:11 Get_Next_Record: <<>> notseen off
01/22/06 22:00:11 Get_Next_Record: >> local MYHD Ant2
01/22/06 22:00:11 Get_Next_Record: surface
01/22/06 22:00:11 Get_Next_Record: Dr. Phil
01/22/06 22:00:11 Record_This: Run date/time 2006/01/22 22:00:11
01/22/06 22:00:11 Record_This: Recording date 2006/01/23
01/22/06 22:00:11 Store_channel: Channels 0 Int I20361.labs.zap2it.com Ext WFLDDT Virtual 32 Physical 31
01/22/06 22:00:11 Store_channel: Channels 1 Int I20452.labs.zap2it.com Ext WMAQDT Virtual 5 Physical 29
01/22/06 22:00:11 Store_channel: Channels 2 Int I20454.labs.zap2it.com Ext WBBMDT Virtual 2 Physical 0
01/22/06 22:00:11 Store_channel: Channels 3 Int I20455.labs.zap2it.com Ext WGNDT Virtual 9 Physical 0
01/22/06 22:00:11 Store_channel: Channels 4 Int I20456.labs.zap2it.com Ext WLSDT Virtual 7 Physical 0
01/22/06 22:00:11 Store_channel: Channels 5 Int I30415.labs.zap2it.com Ext WTTWDT Virtual 11 Physical 47
01/22/06 22:00:11 Store_channel: Channels 6 Int I34662.labs.zap2it.com Ext WPWRDT Virtual 50 Physical 51
01/22/06 22:00:11 Store_channel: Channels 7 Int I36111.labs.zap2it.com Ext WTTWDT2 Virtual 11 Physical 47
01/22/06 22:00:11 Find_Slot_For_Schedule_Entry: Schedule slot 0
01/22/06 22:00:11 Schedule_Program: Input 1 PhyCh 0 VirCh 2 SubCh 1 DateMode 0
01/22/06 22:00:11 Schedule_Program: 2006/01/23 start 16:00 stop 17:00 Week 2 FileType 2 TunerInputMode 1
01/22/06 22:00:11 Schedule_Program: DefaultfileName 1 FileName C:\\HD Stream\\WBBMDT20060123Dr. Phil.tp FileNameStyle 9
01/22/06 22:00:11 Schedule_Program: DirStyle 0 ChNum ChName WBBMDT title Dr. Phil
01/22/06 22:00:11 Find_Slot_For_Schedule_Entry: Schedule slot 1
01/22/06 22:00:11 Access_Registry: nInput 1 nPhyCh 0 nVirCh 2 nSubCh 1 nDateMode 0
01/22/06 22:00:11 Access_Registry: nYear 2006 nMonth 1 nDay 23 nWeek 2 nFileType 2
01/22/06 22:00:11 Access_Registry: nTunerInputMode 1 StHr 16 StMin 0 EdHr 17 EdMn 0
01/22/06 22:00:11 Access_Registry: DfltFN 1 FN C:\\HD Stream\\WBBMDT20060123Dr. Phil.tp FNStyle 9 DirStyle 0 sChNum
01/22/06 22:00:11 Access_Registry: sChName WBBMDT sTitle Dr. Phil
01/22/06 22:00:11 Schedule_Program: Input 1 PhyCh 29 VirCh 5 SubCh 1 DateMode 0
01/22/06 22:00:11 Schedule_Program: 2006/01/23 start 19:00 stop 20:00 Week 2 FileType 2 TunerInputMode 1
01/22/06 22:00:11 Schedule_Program: DefaultfileName 1 FileName C:\\HD Stream\\WMAQDT20060123Surface.tp FileNameStyle 9
01/22/06 22:00:11 Schedule_Program: DirStyle 0 ChNum ChName WMAQDT title Surface
Done
post #245 of 2788
I think I understand what you are saying but haven't a clue as to what happened. The output looks normal, Dr. Phil got scheduled first in slot 0 and then Surface in slot 1. It even displays Dr. Phil in slot 0 when scanning for a slot for Surface.
It looks correct. But my eyes quickly focused on the fact the title, Dr. Phil, has a period in it. I don't think this should confuse RT, not sure MYHD should have a problem either, just an observation.
Yes, the physical channel looks to be a problem. I have to look at Zap2It's internal tables. You can either post your xml here or email me the zipped xml.
post #246 of 2788
Is this an OTA setup or cable system?
post #247 of 2788
Allen,
I'm having the nPhyCh being set to 0 problem with build 1/22. This of course causes MyHD to invalidate the reservation.
01/23/06 11:33:21 Record_This: **********************************************************
01/23/06 11:33:21 Get_Next_Record: >> showaddedschedule
01/23/06 11:33:21 Get_Next_Record: >> today
01/23/06 11:33:21 Get_Next_Record: >> xmlfilename c:\\HDTV_Tools\\XMLTV\\xmltv-0.5.42-win32\\oneday.xml
01/23/06 11:33:21 Get_Next_Record: >> showallchannels
01/23/06 11:33:21 Get_Next_Record: <<>> showallprograms
01/23/06 11:33:21 Get_Next_Record: <<>> showoldschedule
01/23/06 11:33:21 Get_Next_Record: << --- options
01/23/06 11:33:21 Get_Next_Record: << channel
01/23/06 11:33:21 Get_Next_Record: << directorystyle title
01/23/06 11:33:21 Get_Next_Record: << filenamestyle date_time
01/23/06 11:33:21 Get_Next_Record: << notseen
01/23/06 11:33:21 Get_Next_Record: << remote remote_host_name
01/23/06 11:33:21 Get_Next_Record: << reruns
01/23/06 11:33:21 Get_Next_Record: << scheduleconflicts
01/23/06 11:33:21 Get_Next_Record: << showaddedschedule
01/23/06 11:33:21 Get_Next_Record: << showallchannels
01/23/06 11:33:21 Get_Next_Record: << showallprograms
01/23/06 11:33:21 Get_Next_Record: << shownotseen
01/23/06 11:33:21 Get_Next_Record: << showoldschedule
01/23/06 11:33:21 Get_Next_Record: << timeoffset -8
01/23/06 11:33:21 Get_Next_Record: << today
01/23/06 11:33:21 Get_Next_Record: << tomorrow
01/23/06 11:33:21 Get_Next_Record: << xmlfilename
01/23/06 11:33:21 Get_Next_Record: << ----
01/23/06 11:33:21 Get_Next_Record: >> local MYHD ant1
01/23/06 11:33:21 Get_Next_Record: Alias
01/23/06 11:33:21 Get_Next_Record: Bones
01/23/06 11:33:21 Get_Next_Record: Charmed
01/23/06 11:33:21 Get_Next_Record: Ghost Whisperer
01/23/06 11:33:21 Get_Next_Record: Invasion
01/23/06 11:33:21 Get_Next_Record: Medium
01/23/06 11:33:21 Get_Next_Record: Surface
01/23/06 11:33:21 Get_Next_Record: Smallville
01/23/06 11:33:21 Get_Next_Record: Veronica Mars
01/23/06 11:33:21 Get_Next_Record: >> reruns
01/23/06 11:33:21 Get_Next_Record: Nova
01/23/06 11:33:21 Record_This: Run date/time 2006/01/23 11:33:21
01/23/06 11:33:21 Record_This: Recording date 2006/01/23
01/23/06 11:33:21 Store_channel: Channels 0 Int I19609.labs.zap2it.com Ext KOPBDT Virtual 10 Physical 27
01/23/06 11:33:21 Store_channel: Channels 1 Int I20292.labs.zap2it.com Ext KATUDT Virtual 2 Physical 43
01/23/06 11:33:21 Store_channel: Channels 2 Int I20378.labs.zap2it.com Ext KGWDT Virtual 8 Physical 0
01/23/06 11:33:21 Store_channel: Channels 3 Int I21255.labs.zap2it.com Ext KPDXDT Virtual 49 Physical 48
01/23/06 11:33:21 Store_channel: Channels 4 Int I21722.labs.zap2it.com Ext KOINDT Virtual 6 Physical 40
01/23/06 11:33:21 Store_channel: Channels 5 Int I24507.labs.zap2it.com Ext KPTVDT Virtual 12 Physical 30
01/23/06 11:33:21 Store_channel: Channels 6 Int I34621.labs.zap2it.com Ext KWBPDT Virtual 32 Physical 33
01/23/06 11:33:21 Check_Program: >>>>>>>>>>>>>>>>>>>> Skipping rerun Alias on KATUDT 1/23 0:35 till 1:35 or 60 minutes
01/23/06 11:33:21 Find_Slot_For_Schedule_Entry: Schedule slot 0
01/23/06 11:33:21 Schedule_Program: Input 0 PhyCh 0 VirCh 8 SubCh 1 DateMode 0
01/23/06 11:33:21 Schedule_Program: 2006/01/23 start 20:00 stop 21:00 Week 2 FileType 2 TunerInputMode 1
01/23/06 11:33:21 Schedule_Program: DefaultfileName 1 FileName D:\\Recordings\\MyHD\\Surface\\200601232000.tp FileNameStyle 1
01/23/06 11:33:21 Schedule_Program: DirStyle 6 ChNum ChName KGWDT title Surface
01/23/06 11:33:21 Find_Slot_For_Schedule_Entry: Schedule slot 1
01/23/06 11:33:21 Schedule_Program: 2006/01/23 start 22:00 stop 23:00 Week 2 FileType 2 TunerInputMode 1
01/23/06 11:33:21 Schedule_Program: DefaultfileName 1 FileName D:\\Recordings\\MyHD\\Medium\\200601232200.tp FileNameStyle 1
01/23/06 11:33:21 Schedule_Program: DirStyle 6 ChNum ChName KGWDT title Medium
Done
post #248 of 2788
Originally Posted by Cris Moore View Post
Allen,
Need to look at the output. Include ShowAllChannels because that is the table where I get the data.
post #249 of 2788
Post updated.
Well that explains why nPhyCh is being set to zero. Is this coming from Zap2It like this?
Update:
Doesn't look like it. The information seems correct in the XML file (oneday.xml):
8 KGWDT
8 KGWDT PC:97062
8
46 KGWDT fcc
KGWDT
KGWDT (KGW-DT)
NBC Affiliate
post #250 of 2788
Post updated.
Update:
8 KGWDT
8 KGWDT PC:97062
8
46 KGWDT fcc
KGWDT
KGWDT (KGW-DT)
NBC Affiliate
Thanks for posting the xml portion. No reason why the 46 shouldn't have been picked up. Look at it when I get home.
post #251 of 2788
Post updated.
Update:
8 KGWDT
8 KGWDT PC:97062
8
46 KGWDT fcc
KGWDT
KGWDT (KGW-DT)
NBC Affiliate
Post a fix tonight.
post #252 of 2788
Does anyone that is using Record This allow hibernation???
I'm curious since the app I've been working on seems to schedule everything just fine and work fine too, as long as the PC isn't hibernating. If so, it doesn't wake up. My theory is that a simple schedule write to the registry is not setting the proper wake up calls in the bios. It would be helpful to me to confirm this using Record This, and possibly determine whether there are other gotchas that both Allen and I need to be concerned about.
post #253 of 2788
I'm setting this up as OTA right now. I do have cable/QAM connected to the card though.
I'll wait for the next version as the physical 0 may have something to do with this?
post #254 of 2788
I'll set a recording for 5:30 using record this and put my machine in standby.
post #255 of 2788
hdtvincr, (what's your name?)
Since you don't have a thread for MyHDAuto I'll post a couple of problems that I have found here.
Problem 1
Not all EPG channels are listed in the EPG DT Channel dropdown box.
Details
It seems that the EPG DT Channels is a list of the channel id's at the beginning of the XML file. The EPG box lists them in the order they are encountered. The one that I am always missing the the FIRST "channel id" in the list.
Workaround
Manually added the mapping to the ch_maps.txt file.
Problem 2
The Filename is set to the Folder setting when exiting the Options dialog the first time.
Details
1) After deleting the ch_maps.txt and config.cfg file start MyHDAuto.exe.
2) In the Options dialog set Folder (Title) and Filename (Date & Time).
3) Browse and select the EPG File and map the channels.
4) Select X to close dialog. (There is no OK or Close button)
5) Select Options and open the dialog again.
6) Filename is now the same as Folder name.
Workaround
Set Filename back to Date & Time and close the dialog. Setting will stick this time.
post #256 of 2788
Yes, I found the problem with channel 0 and will post a new RT a bit after I get home.
post #257 of 2788
Cris,
Tim is the name. I don't want to clutter up Allens thread, so I went ahead and started my own:
MyHDAuto Thread
post #258 of 2788
Didn't wake on my first try. Now IRC says 10:30 when I thought I was getting 5:30. Weirdness
Oh now I see, it scheduled both times!
post #259 of 2788
Just to verify.... You had a 5:30 capture setup and it did NOT wake up???
post #260 of 2788
Correct.
post #261 of 2788
Thanks for the verification.... I don't have to pull out the rest of my hair now!
post #262 of 2788
Fixed the channel zero problem and tweaked the output a bit.
Record_This.zip 241.2890625k . file
post #263 of 2788
Looks good Allen.
post #264 of 2788
post #265 of 2788
I posted the right exe but the wrong ini. I updated the documentation as some have requested (NotSeen) but didn't post the right ini. I'm going to make one more release tonight with the right ini and tweak the output by adding the network (ABC,CBS....) to the channel name and an output line when a program is skipped because the start time has already passed. That release does that but I thought I'd better tell the user. Then I've got to look into other stuff.
Thanks for any input.
post #266 of 2788
Allen,
A possible feature for an "unspecified" future release.
- The ability to specify a recording time block of some type.
Why?
I have it set up to record PBS Nova reruns. Typically one is shown in the early in the day and one in the evening. I would like the ability to tell Record_This to only schedule this show after 8:00pm and skip the one earlier in the day.
Perhaps a scheduling time block might work like this:
SchedulingTimeBlock 20:00 - 24:00
If a show is found to record and is within the scheduling time block then it gets added otherwise it gets skipped.
This may be a feature that no one else is interested in. I leave it to you to determine its priority (if any).
post #267 of 2788
Allen,
Why?
Or Fusion support!
post #268 of 2788
Since we have two developers working on similar products perhaps we can get one developer to concentrate (at least initially) on Fusion support and the other on MyHD QAM.
If they are willing I suggest that:
- Allen concentrate on MyHD\\Fusion OTA support
- Tim concentrate on MyHD OTA\\QAM support
Allen\\Tim what do you think?
post #269 of 2788
That were my thoughts.
post #270 of 2788
Originally Posted by Andy81 View Post
Or Fusion support!
when we say fusion support, do we mean fusion support, or can we talk more in general terms...say any card with BDA drivers support? Please?
I am not sure if there is a major difference, and I am sure that each manufacturer implements it differently, but I would love my KWorld ATSC-110 to be able to be controlled by this as well...any thoughts?
