Originally Posted by
DPlettner
Allen has updated RT to be compatible with CW_EPG.
For existing CW_EPG users
RT provides an easy way to insert manual reservations into CW_EPG. RT also has a few more specialized scheduling options, such as joining back-to-back programs on the same channel into a single reservation, or the ability to add additional padding to a program if a different trigger program aired earlier in the day (which works well for certain live events that delays schedules).
-Dave
ok, i was able to get the new rt+cwepg to work using hdhr and ota but something is not quite there for qam... what am i missing???
see rt log below:
07/31/10 00:11:31 Record_This: ************************************************************
07/31/10 00:11:31 Record_This: Compile date/time Jul 28 2010 11:14:29
07/31/10 00:11:31 Record_This: Ini filename Record_This.ini
07/31/10 00:11:31 Get_Next_Record: >> ChannelTable HDHRota0
07/31/10 00:11:31 Get_Next_Record: >> Channel wjctdt 70 0 1 qam256
07/31/10 00:11:31 Get_Next_Record: test_Movie [at 00:15-00:17 on wjctdt date 07/31/2010]
07/31/10 00:11:31 Get_Next_Record: >> local HDHR [DeviceId 10161ADA tuner 0 Folder "c:\\hdtv" Identifier HDHRota0 CWHDHR 8181]
07/31/10 00:11:31 Record_This: Run date/time 2010/07/31 0:11:31 DST 1
07/31/10 00:11:31 Record_This: Recording date 2010/07/31
07/31/10 00:11:31 HDHR_Parse_Message: HTTP/1.0 200 OK
07/31/10 00:11:31 Store_Dont_Care: >>>>>>>>>>>>>>>>>>>> Inserting manual reservation for test_Movie on 7/31/2010 at 0:15-0:17 channel wjctdt
07/31/10 00:11:31 List_Scheduled: Program 0 wjctdt 0:15- 0:17 7/31 0 test_Movie
07/31/10 00:11:31 Insert_Here: Program 0 on local HDHR tuner 0(0)
07/31/10 00:11:31 Schedule_Using_CWHDHR: CWHelper call capture?channelname=70.1&datetime=7/31/2010 0:15&datetimeend=7/31/2010 0:17&tuner=10161ADA-0&filename=c:\\hdtv\ est_Movie.tp&protocol=qam&title=test_Movie
CW_EPG Helper Interface
Not able to schedule capture for 70.1 Slot: start [07/31/10 00:15:00] stop [07/31/10 00:16:59]
Sat Jul 31 00:11:31 EDT 2010 ERROR - capture was not defined.
channel 70.1 qam not found on 10142327-0 lineup.
channel 70.1 qam not found on 10142327-1 lineup.
channel 70.1 qam not found on 10161ADA-0 lineup.
channel 70.1 qam not found on 10161ADA-1 lineup.
channel 70.1 qam not found on HDTV3Silver+/3Gold.3 lineup.
channel 70.1 qam not found on MYHD lineup.
getAvailableCapturesForChannelNameAndSlot returned no captures for 70.1 10161ADA-0 Slot: start [07/31/10 00:15:00] stop [07/31/10 00:16:59]
Done
looks like rt does not like my channel definition for some reason.
here's a partial dump of my channels :
steve
