Originally Posted by Dweezilz
Since lense shift as far as I know is 100% manual, I don't think that port can do anything about that. If there were motors controlling the lense shift and those were controlled by the internal programming (remember we aren't talking about digital shift) then maybe it would, but I was under the assumption it was totally manually adjusted and maintained. Now if the problem is not the manual lense shift and that the Z4 is digitally shifting the picture that would be interesting and would be a firmware bug.
So explain again what the tech was talking about in regards to pushing on the lense? So use the dials on the side while you are pushing down on the lense? That sounds kinda scary since it would seem that's forcing it. Is he saying that you can push it down to ensure it's in a stable position and won't move? I'm just leary of pressing down on the lense when that is the 1st I've heard of it.
I'm going to call Sanyo to see what they say as far as the drifting.
It does sound a little strange to push the lens down while moving the dials. From what I gathered, your not pushing the lens in the opposite direction of the way you want to go. Rather, push the lens in the direction you want to shift and then lock. Not sure if I'm gonna try this, I just might live with the drifting.
