I'll try to summarize what we know/don't know about the 1080p MD6580n and MD5880n DLP models here. If there is other info you would like to see summarized here, let me know. Thanks.
hp Microdisplay info can be found here:
http://www.shopping.hp.com/webapp/sh...dtv&catLevel=2
All models have the following inputs:
2 HDMI (480i/p, 720p, 1080i/p*)
2 Component (480i/p, 720p, 1080i/p**)
1 VGA (480i/p, 720p, 1080i/p***)
1 USB
1 Serial
3 Composite/Svideo
2 Cable
1 CableCard
5 Analog RCA Audio
* Supports 24, 30 and 60fps.
** Supports 24, and 30fps.
*** Supports 24, and 30fps but we have heard that the maximum resolution is 1280x1024p60
All models have the following outputs:
1 Analog RCA Audio out
1 Digital Coaxial Audio out (configurable)
Dimensions:
MD5880N
38.1" High x 60.3" Wide x 19.0" Deep
The front legs (of both sets, actually) are 45" apart (measuring to the outer edge of the feet). There are flanges that extend from the feet about 3 more inches outwards towards the outer edges of the TV. The flanges have about a 1/4" gap beneath them and don't actually touch the surface of a stand the TV sits on, and don't appear to be designed to bear weight.
The foot on the left front is 9.5 inches from the outside left of the tv. The foot on the right front is 7 inches from the outside right of the tv.
The actual footprint of the 58" is only about 12 inches deep, measuring from the front of the front feet, to the rear of the back feet.
The rear feet on the 58" are about 13.5" back from the front edge of the set.
The width of the set at the deepest part of the back is 33".
From the bottom edge of the screen to the top of a stand the TV is sitting on is about 9. Most of that space is taken up by the fold-down front panel that hides the front connections.
The front base of the TV slopes back toward the screen. There is approximately 1.75-2 inches difference between the front of the TV (the hump at the bottom) and the actual screen.
hp stand for MD5880N
60 1/4" L x 21 9/16" W x 19 15/16" H
HP site link-> http://www.shopping.hp.com/webapp/s...1A&cross_link=1
The vertical measurements between the shelves: 9 3/8 for the top shelf, and 5 71/6 for the bottom shelf.
Box dimensions for MD5880N
66" Long x 25" Wide x 50" High
MD6580N
41.6" High x 66.3" Wide x 20.9" Deep
The front legs (of both sets, actually) are 45" apart (measuring to the outer edge of the feet). There are flanges that extend from the feet about 3 more inches outwards towards the outer edges of the TV. The flanges have about a 1/4" gap beneath them and don't actually touch the surface of a stand the TV sits on.
The actual footprint of the 65" is only about 12 inches deep, measuring from the front of the front feet, to the rear of the back feet.
The rear feet on the 65" are about 16" back from the front edge of the set.
The width of the set at the deepest part of the back is 36".
The front base of the TV slopes back toward the screen. There is approximately 1.75 inches difference between the front of the TV (the hump at the bottom) and the actual screen.
hp stand for MD6580N
66 3/8" L x 21 9/16" W x 19 15/16" H.
HP site link->http://www.shopping.hp.com/webapp/s...2A&cross_link=1
Box dimensions for MD6580N
72.5" Long x 29.5" Wide x 48" High
Cables:
The cables run from under the set (from the font connects) and can then be run through a hole in the back of the stand to your components. There are no visible wires from the front or the sides. You have to look behind the set along the wall to see wires at all.
There is a depression in the HP stand that mates to the bottom of the TV, and the TV can be screwed into the stand from below.
Heat Venting:
The area on the back of the set where venting occurs is in the lower ΒΌ of the set on both ends and along the back, inset from the outer edge of the set by about 12. If you are worried about venting w/the set in an enclosed space, you'd want air flow clear around the bottom 1/4 to 1/3 of the set.
Tracking information:
If you order from HP, you will receive 2 emails.
1. order confirmation
2. Shipment confirmation
In your shipment confirmation, you should get a 5-6 digit tracking number. That's the North American tracking number.
Here is where you track it.
http://www.northamericanhomeexpress....ertracking.asp
Enter the tracking and your zip. Leave phone number BLANK!
It would seem they only update it daily like usps. so do it daily. Once they receive your tv from HP (2-3 days), you can call NA and they will forward you to your local facility so you can schedule a delivery.
This might work for East Coast, but I'm on West Coast, and it maybe different.
Customer Support information:
The ONLY support center for these TVs is located in Ontario, Canada. It is staffed 24 hours a day, 7 days a week. If you ended up offshore then somehow the phone system misdirected you.
For people calling in, it is recommended that when prompted for the product you're calling in about, say "Digital Television". That *should* get you through to the correct department.
Other threads discussing hp sets:
720P owners->http://www.avsforum.com/avs-vb/showthread.php?t=591737
Calibration->http://www.avsforum.com/avs-vb/showthread.php?t=595889
Professional Reviews->http://www.avsforum.com/avs-vb/showthread.php?t=592075
HTPC 1080p setup->http://www.avsforum.com/avs-vb/showthread.php?t=597362
S&V Editors Choice Award->http://www.soundandvisionmag.com/art...rticle_id=1152
Hewlett-Packard Discount programs:
FEDERAL GOVT:
http://government.hp.com/forms/epp.asp?agencyid=1
STATE & LOCAL GOVT:
http://government.hp.com/forms/epp.asp?agencyid=2
ACADEMIC PURCHASE PROGRAM:
https://eclipse.ebus.hp.com/dn/jsp/products_you.jsp
Questions to answer:
1) Do the HDMI inputs actually support 1080p as documented?
We have confirmation that the ATI 9800 All-in-Wonder will display 1080p at 60 fps to the set.
2) Do the Component inputs actually support 1080p as documented?
3) Does the VGA input do 1080p?
No. It has been confirmed the max resolution is 1280x1024 @60hz
4) What is the serial input for?
5) Does the digital-audio-out properly pass 5.1 if present on the HDMI input?
6) How does the USB firmware upgrade work?
7) Is it a problem that 1080i/p over the component cables are only 24 or 30fps instead of 60? Is the difference noticeable?
Answers to common questions:
1) How is the fan noise? Most common answer: audible in a slient room but not at normal listening volume. Some have reported louder noise but this has been attributed to a noisy color wheel. Those with noisy color wheels have had their light engine replaced.
2) How is the black level? Most common answer: Excellent
3) How is the black detail? Most common answer: Excellent
4) Is there artifacting with fast motion video? Most common answer: Not detected as yet
5) SDE? Most common answer: None. Even up close.
6) SSE? Most common answer: None detected so far.
Update on a report being investigated:
Second update:
7) How is the OOB calibration? Most common answer: Good
8) How does SD look? Most common answer: Varies from quite good to pretty dismal depending on how bad the "garbage-in" is.
9) Do the sets do 3:2 pulldown on 480i and 1080i? Yes
10) Where can these sets be purchased?
Good Guys
J&R Music Store
Nebraska Furniture Mart
BrandsMart USA
PC Richard
tvauthority.com [AVS Forum members click here]->http://www.tvauthority.com/avs-members-only.asp
Crutchfield.com
hpshopping.com
11) Is the hp stand required to conceal the wires coming from the flip-down, lit, front connection area? No. Any stand will work. The wires pass through the set out the back.
12) Does hp offer an Extended Warranty? Yes. HP 3-year, in-home extended warranty: $ 499. You can get one by calling in with a credit card, tv serial number, and date & location of purchase to HP Total Care Extended Service Plan 1-866-234-1377. NOTE: The warranty does not cover the bulb.
13) Does the set use discrete remote control codes for device selection, etc?
No. But this feature is expected in the first firmware update.
14) How would you describe the appearance of these sets? WAF? Most common answers: "The best I've seen." "Even the wife loves it." "Completely non refelective." "Blends beautifully with traditonal or contemporary decor."
15) What was fixed/changed in firmware revision .12 (base was .10)?
- Channel switching is much improved.
- HDMI audio issues are fixed.
- Custom RGB settings are retained.
- Sharpness default is now 5.
- Volume leveling is fixed.
- Computer connection issues are resolved (EDID).
- Iris settings are more aggressive.
Device compatibility over HDMI:
SA8300HD Cable/DVR STB: works and produces a great picture but there are reports that some Time Warner customers in some regions will have problems.
Hughes HR10-250 DirecTV/DVR: reportedly has PQ issues over HDMI. Component works great. Being investigated. Update: this turned out to be a bad STB.
ATI 9800 All-in-Wonder: displays 1080p 60 over HDMI to the set. Here is a quote describing the PQ
Sony DVP-NS70H DVD: displays 1080i over HDMI with no shifting issues. The PQ is outstanding!
ATI x800 Pro graphics card:
Universal Remote Compatiblity:
Harmony 360 (aka Harmony Xbox remote)
Harmony 520
Harmony 880
Harmony 890
Problems reported:
1) Apparently, the HP stands are not being packed/shipped very well. Most are arriving damaged! Update: This issue has apparently been addressed by hp.
2) PIP functionality is not on-par with competitors. Only 1 HD source available.
Update:
3) Remote is not backlit.
Update: hp did not say it would be backlit. They said it would been illuminated (which it is, sorta). I'm not overly pleased with this response but I guess it is accurate
4) There have been some reports of noticable fan noise. The suggestion has been to contact hp support as most owners do not hear the fan at normal listening levels.
5) Most owners are reporting minor tilting of the display image with some devices. There have been some more extreme cases as well but the thought is that those sets were damaged during delivery.
Update: a technician can correct this issue with a simple adjustment.
6) Some owners are reporting pincushioning of 4:3 images.
7) Certain ATI Graphics devices are not working when connected to an HDMI port at 1080p.
Update: This problem was solved with the .12 firmware release.
8) There are intermittent reports of audio problems over HDMI.
9) Some owners have reported a white line across the top of the screen when connected over component. Update: This problem was solved with the .12 firmware release.
10) Volume leveling does not work.
11) There have been reports of noisy color wheels. hp has been replacing light engines to address this concern.
12) Some owners are experiencing speaker hum to various degrees. Some owners were able to correct the problem by having the cable company install a noise filter on the cable drop coming in to the house. Others have resorted to disconnecting the internal speaker wires. Others have had the hp noise cancellation filter installed.
Things we'd like to see fixed:
1) Channel switching can be slow with certain sources. This is supposedly being addressed in the upgrade available with the free 128MB USB drive.
2) Panorama stretch mode is not working quite right. It seems to be throwing away data from the top and bottom of the picture. Update: quite a few people seem to like this stretch mode as is. There is no consensus on this!
3) If different RGB settings are created for HDMI1 and HDMI2, when you switch between the HDMI inputs, the RGB values shown in the user menu are correct but the settings are not applied to the screen unless you change an RGB setting again in the user menu.
4) In windows, when connected to a 1080p model, the monitor is displayed as MD5020N.
Enhancements we'd like to see added:
1) Add an EPG. Please. Pretty please!
2) Update the "Info" display so that it displays info on the second window in PIP and split sreen modes - at a minimum identify the source of the secondary window and report the current Aspect setting (panorama, zoomed, etc).
3) Update the "Info" function so that it clears any channel commands entered but not executed by the set...e.g., if I am changing channels and hit 55 instead of 57, hitting the "Info" button should cancel the channel command so I can start over and not have the set switch to the wrong channel.
4) Allow the HDMI audio input to work with either HDMI1 or HDMI2. I believe the function of this audio input is for those that are using a DVI to HDMI cable for video that want to pipe in an audio signal as well (i.e. HTPC users that have DVI-out video cards).
5) Add the ability to control the behavior of the aperture on the iris.
Update:
6) Greatly enhance the help text to better explain the available user menu settings!!!
Darrell
1 USB
1 Serial
3 Composite/Svideo
2 Cable
1 CableCard
5 Analog RCA Audio
Dimensions:
MD5880N
MD6580N
Cables:
Heat Venting:
FEDERAL GOVT:
STATE & LOCAL GOVT:
Originally Posted by The Shadow
Okay, here's what I've been able to find out:
The Digital output will pass 5.1 audio only from CableCARD, Clear QAM cable, or OTA HDTV inputs (eg. Digital tuner inputs). It will only pass 2.0 audio from an HDMI input. Users that wish to obtain full 5.1 audio from a DVD player with HDMI should connect their DVD player 5.1 digital audio output directly to their audio receiver, bypassing the TV.
Hopefully this puts a rest to the 5.1 debate
Now, onto more important debates: nachos or cheesypoofs for the football party!
Originally Posted by jwoods24
Procedure For USB Firmware Upgrade
(For HP MDTV's (MD5020, MD5820, MD5880, MD6580)
Rev. 11/7/05
As of this FW revision, one set of FW will upgrade all types and sizes of HP MDTV's to run properly.
Be sure to read all the instructions before attempting to load firmware.
Upgrading to New FW with USB Memory Stick
Turn TV OFF.
Remove cableCARD
Remove input cables (HDMI and VGA connections)
Unplug TV AC cord for 10 seconds. This is done to put the TV into a known state.
Insert USB stick drive into USB port. NOTE: USB drive can take up to 20 seconds before it starts loading.
Plug AC cord back in. DO NOT TURN TV ON! Tunring TV on during upgrade process will corrupt files in the TV!
Firmware loads automatically. This upgrade process is indicated by three LED's on the front panel that flash sequentially from Left to Right. The process will take about 30 minutes. Sometimes the sequential flashing will stop momentarily, but should re-start automatically.
Firmware loading is completed successfully when center blue LED flashes repeatedly ON and OFF (without any red lights).
Do not pull USB drive out of port until the FW loading process has completed. Unplugging USB stick may damage TV!
Note: If sequential flashing of red-blue-red LED lights continue for more then 60 minutes, REMOVE USB drive and restart process by starting at Unplug TV AC cord for 10 seconds.
Wait 15 seconds.
Remove USB drive from TV.
Unplug TV AC cord. Wait 10 seconds.
After USB Process Completion
Turn-ON TV. The firmware update screen should appear and indicate that your new FW was loaded with Success. Check for the correct firmware version.
If everything has updated correctly, follow the on screen display instructions to return the TV to normal use.
NOTE: If you are using a cable or antenna direct input, after a FW upgrade you will need to redo a Cable Scan to automatically find cable channels since all settings return to Factory settings during the FW upgrade. This is done by using the Set-up mode in Settings.
Rev. 11/7/05
Turn TV OFF.
Remove cableCARD
Wait 15 seconds.
Originally Posted by SecondToughest
[*]Navy NCIS on CBS OTA in 1080i was mixed. Sometimes (usually darker or far-away shots) looked excellent. But broad expanses of lighter colors (like faces) tended to have a "grainy" or "noisy" texture to them. Almost like someone had sprinkled a fine sand over the screen in those areas. The "specks" were static relative to the screen, so it was somewhat similar to SDE. Given that other 1080i sources looked so good, I'm assuming this has more to do with the signal than the TV, but it was a bit discouraging. Has anyone else experienced something similar?
Second update:
Just to set everyone's mind at ease, I've been watching several HD channels tonight vi the cable connection (as opposed to OTA antenna) and I'm happy to say that they look *gorgeous*. No more "speckles". Much better.
The POS antenna is going straight back to into the hellmouth from whence it came tomorrow.
Good Guys
J&R Music Store
BrandsMart USA
PC Richard
Crutchfield.com
hpshopping.com
Originally Posted by mistertam
The HD Tivo settings must be changed. The user must change the Video output to 1080i, After that, the PQ is amazing. If you do not, the picture will display at 720.
HDMI connection to the TV is crisper than using component.
Component showed slight signs of grain at 8' distance as opposed to using HDMI connection though both look overall better than my Samsung 720P which i still have side by side w/ my HP. Color and contrast seem to be amazing and sharp.
I used the World Series via OTA to test the above.
Originally Posted by Reldan
I just got my HP md6580n last night. I could not possibly ask for more out of a HTPC TV than this.
I'm connecting via DVI-HDMI out of my ATI x800 Pro video card. I go into the Catalyst Control Center and choose 1080p mode out of the HDTV Support tab, then set the resolution to 1920 X 1080 60 Hz in the Display Manager.
I wind up getting some overscan, maybe 5-8% and the picture isn't that great, but the set tells me in the info that it's getting a 1080p signal. I try using some slightly lower resolutions to fix this, and it shrinks the desktop down and says it's getting 1280X1024 60Hz.
This is bad, I think, so I put it back on 1920 X 1080 60 Hz and go into the TV user menu. Under Advanced Picture I look at the Aspect setting, and sure enough there's one labelled "PC". I select that and WHAM, perfect fit with no over/underscan. I then grab a calibration image with alternating black and white lines and tile that as my background, and the lines appear distinctly when viewed up close. 1:1 pixel mapping even.
On top of that, there is another setting in Advanced Color called DVI Color, with a setting called PC and a setting called Default. This toggle switch changes the TV between video grayscale (16-239) and PC grayscale (1-255) instantly.
Oh, and the picture is nuts for both Battlefield 2 at 1920X1080 and Zoomplayer/DScaler/FFDShow upscaling to 1080p.
Harmony 520
Harmony 880
Harmony 890
Problems reported:
Update:
Originally Posted by DPlettner
I just tried putting an OTA HD signal in one window, and my 1080p PC desktop in another windows, and it works fine for both POP and PIP. I do have the limitation that one window must be from the internal tuner while the other widows must come from one of the non-RF inputs. However, it appears that both can be HD.
Update:
I was experimenting a with the different picture modes tonight. When I reported seeing the affect of the aperture, I was using Movie mode. However, in Studio mode, the I can't see the affect.
It appears that the aperture functions differently based on the picture mode. Well I have not tested this extensively, my quess is that the sensitivity of the aperture is highest in Movie mode, and lowest in Vivid mode.
Darrell
