Assuming it's the primary bearing of the color wheel, it's really hard to say. IIRC, the bearing is similar to the bearings used in hard drives before fluid dynamic bearings became popular. With those old hard drives, sometimes a noisy hard drive would last a long time. I think there is a decent change that it won't get worse quickly, and you might get another year out of the set.
-Dave
-Dave
the front access dooor light is even out.. I have checked door swithch, tried switching bulbs( 3 different) blowing out dust. pluging directly into wall, letting it sit over-night(when I did this the green light on the PowerSupply came on till I pressed the on button then the front blue flicked for a nanosecond then the green light went out and dead again) any thoughts on a plan of attack would be appreiciated.... can I jumper the interlock and/or thermal to test them
(are they NO or NC respectfully) thanks for your time.
