Progress Bar
post #1 of 5
Boy I love my UTV but just recently I noticed the progress bar doesnt display or the display at the top corner when I FW or RW but it still goes FW and RW. Can anybody know what could be causing this?
post #2 of 5
Is your HD upgraded?
MIne sometimes does that since I upgaded to a 160 GB .
It seems to happen when
the drive is filled up.
But always comes back.
post #3 of 5
Unplug the UTV for 30 seconds and it will go back to normal.
post #4 of 5
Experienced the same awhile back. The hard reboot (unplugged for a bit) did the job. Think it has only happened a couple times over the past 3 or 4 years or so...
post #5 of 5
Yep that did the job. matter of fact after I post my first post I went ahead and unplugged it for 5 minutes. so thanks for the reply anyways.
  Back to Forum: Microsoft UltimateTV PVR
This thread is locked
