Let me preface my questions with a little backround:
I have a 125" MDF screen with a Sanyo Z-3. With a 3/8 nap roller I rolled two coats of primer and two coats of UPW High Gloss enamel with the board flat on the ground. Between each coat of primer and UPW I used a wet sanding sponge over the entire surface to smooth out any roller marks and bumps, but I didn't completely sand it smooth to the touch. I now have the board permanently mounted on the wall (long story) but have not yet applied the two coats of RS-MMMaxx or sanded the final coat of UPW. I plan on renting a sprayer, practicing with it and spraying it in place on the wall. I plan on renting a HD sprayer, and I hope it's up to the task.
Now to the questions...
I notice that the final coats of UPW has left somewhat of a "texture" on the board. When projected upon, there is a sheen of hotspotting over the entire surface of the board, but it's only noticeable from looking at the board straight ahead from your sitting position. I assume this is caused by the small "bumps" that have not yet been sanded and the UPW gloss. Am I correct in assuming this or is my paint job pure crap?
Should I sand this final layer until is is smooth to the touch? Should I just even everything up with the sponge or should I get out the palm sander and work it?
Should I still use two coats of RS-MMMaxx with the sprayer or more? Should I add 4 more oz of Distilled Water for spraying or more? My current mix is:
1qt Behr Ultra Pure White Flat Exterior (HD)
12 oz. Behr Deep Base Flat Exterior (HD)
3 (8oz) bottles - Delta Ceramcoat Metallic Silver #02603 (Michaels)
1 (8oz) bottle - Delta Ceramcoat Pearl #02601 (Michaels)
16 oz. Minwax Polycrylic Satin Finish (HD)
12 oz. Distilled Water
Should I sand in any way the RS-MMMaxx final coat or use as is?
Thanks guys!
Thanks guys!
