[quote=pb_maxxx]ktaillon,
you can certainly use hardboard or sheet rock but you'll want to use an ultra pure white gloss paint as your basecoat. you'll also likely need to do some sanding before the final coat of basecoat to get it as smooth as possible before applying the topcoat mix.QUOTE]
So you don't sand the final coat of base -- only the second-to-last coat of base, right?
Also...
What's up with some people using SM as their base? I have 2 coats of UPW base on there now... what would be the benefit of putting some SM on there? I presume the advantage to SM is enhanced contrast, at the expense of color reproduction, maybe at the expense of gain?
I know I don't sand the final coat of RS. Am I supposed to sand any of the first few coats?
Also...
). Rooms going to start closing in on me with all these coats.
