Paradigm probably better depending which monitor speaker and which Athena you're talking about.
For instance I'm not sure which Paradigm monitor sounds better than the F2 as that Athena is quite a good speaker.
I think the Titan is better than both the B1 or B2 bookshelf.
The Athena B1 and Paradigm Atom are pretty close but the Paradigm has better build quality. The newer versions are probably even better now. The B1 is a 8 year old speaker now with no upgraded versions since the B1.2. they are discontinued now as is Athena overall.
