They are essentially the same. Only dimensions and sensitivity is different. Exact same tweeter and I suspect same drivers. If using with a sub, go for whichever suits your fancy, if using with no sub, I would favor the AS-F2.2 du to their larger size. Even though they are rated for the same frequency response, I suspect the the AS would do the lower notes at a higher SPL
Get the Athena AS-F2. They are not essentially the same speaker as the LS-500B.
The F2 has dual 8" woofers while the LS-500 has dual 6.5" woofers. They use different tweeters also. The F2 was highly reviewed by a couple audio magazines as an excellent bang for the buck speaker.
http://www.stereophile.com/floorloudspeakers/645/index.html
http://www.goodsound.com/equipment/athena_asf2.htm
Edited by afrogt - 12/10/12 at 8:15am
